Hello here,
It's maybe a misunderstanding from my side, but I don't get how the 'Avoid smaller than' can actually add polys in extreme condition.
I'm actually using the meshing tool too create some really low cage from my modeling, I need to create some simple collision for some particle simulation.
So I did some export test with different settings, testing the 'Angle' vs 'Avoid smaller than' parameter.
So far the best setting for my object is 95° for the angle, to remove every fillet from my hires model.
Here's a sample:
And the result:
However if I put 30 in the 'Avoid smaller than' (the cube is 100*100*100 units), it actually adds polys ... does it make sence ?
