Inconsistent selection between computers
All  1  2-4
1645.2 In reply to 1645.1
Hello Otterman,
See link below by Michael, I had a similar problem to you and this solved it
http://moi3d.com/forum/index.php?webtag=MOI&msg=1614.7
HTH,
--Paul
1645.3 In reply to 1645.1
Hi Otterman, yes it is likely that you have the same problem that Paul had, which is a problem with a certain release of the nVidia display drivers where they had a bug that they didn't pay attention to MoI's request to turn off anti-aliasing when doing some selection-related processing on the video card.
You should be able to fix this by turning off anti-aliasing in the driver settings, see the link in Paul's message above.
Please let me know if you need more information on how to do that, or if that does not solve the problem.
You may also be able to solve the problem by updating your video driver to the latest version.
1645.4
Woohoo! Thanks, that did the trick. Oddly enough, it was already set to application-controlled. I changed it to off, applied, then changed it back to application-controlled. Weird, eh? Time to inject my credit card number!
Show messages: All  1  2-4
