Idea for filleting of surface corners....
All  1-13  14
1641.14
Hi Michael'
Thank you for adding it to the wishlist.
>and I suppose corner points of solids as well
Yes good idea!
>One big problem is that the most basic kind of fillet is a circular arc fillet, and it generally isn't possible to fit a circular arc to be simultaneously tangent to 2 non-planar curves.
>So what would you expect to have happen in there if you had the Fillet shape set to Shape: Circular, which is the default?
Ok, in this case the circular option might have to e grayed out and not possible to click.
Or maby another option can be added in the fillet tool that does the "point fillet".
-Fredrik
Show messages: All  1-13  14
