Wishes
All  1-4  5-8
1635.5 In reply to 1635.4
Hi Paul - I see. There is kind of a flip side to that though which is viewing surface smoothness.
I've found that often times kinks or small ripples in surfaces can occur right at those isocurve locations, and when isocurves are displaying it can tend to cover up those little glitches and make them harder to notice until later... With no isocurves being displayed you get a more unobstructed view of the surface itself, that can help when just eyeballing the fairness of the surface.
But yeah with isocurves displayed it does give you an indication of the control point density of the surface though, and overly concentrated density in one small spot is definitely a warning sign.
I'd like to get that in as an option, I'm just not quite sure of when that will happen yet.
1635.6 In reply to 1635.3
Hi Michael
Yes, I do plan to study these more carefully as I take your point.
In your example, it is possible to draw a line of length=100 by initiating the c.lines after starting line command then still keeping the mouse depressed coming down to (D)istance inputting 50 then clicking along perp c.lines....is there a better way apart using this facility?
Rgds,
--Paul
1635.7 In reply to 1635.6
Hi Paul, that one is a bit awkward.
For drawing a line of a particular length, it may be easier to not use construction lines and just draw the line starting at that point, type in "100" for the length (you can just type that directly without clicking, your keystrokes will go in to the x,y,z coordinate box but if you enter a single number in there it will get applied as the distance constraint).
Then grab the line at the midpoint and drag it over to reposition it. That's a bit less mouse gymnastics for that particular thing.
You don't have to use the "Move" command for the repositioning like you would in Rhino - just regular dragging will do it if object snaps are turned on. Grab the line near the midpoint and when you drag it you should see "Mid" highlighted on it until you snap it on to the End of the other one.
One thing that would make that cline maneuver a lot easier would be if you could enter the distance constraint before starting the cline and have it applied to it. This actually works for drawing regular lines (for example you can enter the constraint distance before picking any points and it will get applied when it is possible for it to have an effect), but it does not get picked up in this way for construction lines. I think it will not be difficult for me to patch this up for v2 though.
1635.8 In reply to 1635.7
Thanks for the advice and the above sounds just the job !
Rgds,
--Paul
Show messages: All  1-4  5-8
