Help with modeling
 1-4  5-24  25-44  45-60
1633.25 In reply to 1633.24
>> Is Cinema 4d much better than Carrara is it just that I'm not doing a very good job of rendering.
Well, I can only speak for C4D, not knowing the full potential of the Carrara Render Engine.
Cinema has a solid and quick native engine, capable of excellent results, but what gives it a real boost is the recent implementation of Vray, which, IMHO, is the renderer that gets closest to an unbiased result in a fraction of the time needed with Fryrender, Maxwell or even Indigo.
Dan
"The darker the night, the closer the dawn."
(Buddhist Proverb)
1633.26 In reply to 1633.25
My first render in Carrara was about as simple as one could ever try . I mean LAZY!
I thought neither the object, or the (non) background placement, deserved the time and effort for critical texturing or lighting.
Comparing renders, unless that aspect was indicated as an end result criteria, is not applicable in this exercise I suggest?
1633.27 In reply to 1633.26
Hi Brian
Comparing renders isn't necessary but I am interested. I only started 3d modelling as a hobby last summer and there is a huge amount to learn. I bought Carrara, Bryce and Hexagon but only now use Moi for modelling. I use Carrara for texturing and rendering. There seems to be such differences in the price and ease of use of 3d modelling software that it makes me curious about which is best. Its a subject that I have found it difficult to research as everybody has a different opinion. With Moi being so easy to use I sort of hope that someone will invent shading and rendering programmes that are as good. I like Carrara a lot but when I see the beautiful models made by others I am sometimes tempted to think that they have better tools. In reality I expect they are younger people who grew up with 3d modelling.
Keith
1633.28
Hi Group, my attempt, but I thought I'd 'Pimp my Ride' slightly modified.
Michael is there an easier way to make 'text' follow a curve ?
EDITED: 3 Jun 2008 by DANTAS
Size: 137.8 KB, Downloaded: 169 times, Dimensions: 800x452px
Size: 204.2 KB, Downloaded: 179 times, Dimensions: 800x452px
1633.29 In reply to 1633.27
Hi KEITH,
Here's just an advice about some render engines I know.
If you've got the horse power, like a quad-core or better, unbiased render engines like fry or maxwell are interesting.
They are really easy to understand, more over if you know a little bit how photography works. Even the shaders are really simple to get,
probably not so easy to tweak because of the rendertime, but just with basic presets you can archive really incredible rendering.
Of course I'm only talking about stills image, as you need something like 5-20 hours of cooking for a final frame. (a simple image like the little truck
takes only 5-10 min don't worry :)).
Modo has also a really good engine, they are maybe 10 parameters to tweak in fact for the render itself, but the interface take some times to understand.
Same for the shading system which is not very usual (some kind of photoshop layers system).
Actually my favorite render tool when it's about productivity is still this good old fprime for lightwave. They are no surprises and you have a realtime feedback.
Forget hyper realism of course ... and you need to get lightwave workflow a little bit.
It seems that vray is coming with a realtime render too, curious to see it in action !
Of course it's just I personnal taste here =)
1633.30 In reply to 1633.28
Hehe, I love your personal touch!
Dan
(Buddhist Proverb)
1633.31
I know its mad but I'm going to have a go at this:
http://www.the-blueprints.com/index.php?blueprints/motorcycles/triumph/24435/view/triumph_bonneville_t100_2008/
I'll post back the result in about 6 months.
Keith
1633.32 In reply to 1633.24
Hi Keith,
> Michael I hope you don't mind me using your Moi forum
> to talk about rendering.
Sure, it's totally fine, in fact I'd encourage it.
Certainly a lot of people want to render models after they are done constructing them. It is very much on topic to discuss what you want to do with the model data that you produce using MoI.
1633.33 In reply to 1633.28
Hi Danny,
Nope, sorry - currently there isn't.
1633.34 In reply to 1633.33
A difficult way?
***Modeling Of Ideas***
1633.35 In reply to 1633.34
Hi JTB,
> A difficult way?
The difficult way is just to place each character into position using Transform commands like Move and Rotate.
1633.36 In reply to 1633.35
Keith
Carrara is a fine texturing and rendering app. And, especially, one of the easiest to learn.
I suggest you not even consider another general 3D app untill you are fully conversant with it and, are aware of the full range of options included in it, and budget price plugins available fot it. (Some real frights when you find out what the "big" apps don't include in the basic price!)
Nice to see the great quick modelling that is being done on this thread.
Brian
1633.37 In reply to 1633.35
More like a boring way, not difficult :)
1633.38 In reply to 1633.37
JTB
Your repeated post!
Is this saying anything---loses me?
Brian
1633.39 In reply to 1633.38
I commented Michael's answer... see above :)
1633.40 In reply to 1633.39
I am confused by your addition **Modeling of Ideas*** in each post. It reads as part of your question/answer sentence but I gather it is not?
Brian
1633.41 In reply to 1633.40
Brian,
I believe that is whats known as a 'signature' and not intended to be part of the message / post if you catch my drift?
--Paul
1633.42 In reply to 1633.16
Hi Keith,
>>1. How it looked in Moi with fillet radius set at 0.4
>>2. How it looked when converted to .obj
I am not sure if it related to the fact that MoI will allow an overlap when creating a fillet on a cylinder (that is too big) as I have not seen the problem you mention.
Care is needed when making fillet on a cylinder as it is not allows noticeable when the error I mention does happen.
Simple example:
A cylinder of 3 rad will fillet correctly up to a fillet of R2.99,... a fillet of 3 will fail, but, fillets above that (to a certain size) will be created incorrectly with a surface overlap at the top of the fillet. It is not always obvious, but to show the problem, I have a cylinder of rad 3 with an end fillet of 4:-
- manz
EDITED: 3 Aug 2009 by MANZ
1633.43
Hi All,
I see quite a few have taken part and put forward their own model, nice, I did build the model, but did not texture (attached image).
Any thoughts on what we should build next? Or should I find something a little more interesting that requires the use of more tools within MoI?
- manz
1633.44 In reply to 1633.43
karter
I did grasp the signature idea eventually---it did not seem to appear as such to me--needs a line space !.
Manz
I have started in MoI to do this Jeep Tutorial.
(It may be a bit difficult though)
http://www.cgarena.com/freestuff/tutorials/xsi/jeepmb/index.html
Show messages:  1-4  5-24  25-44  45-60
