texture coordinates -> mapping and rendering in Viz 2007
161.1
Dear all
i downloaded moi3d yesterday and i like it very much!
After doing some 3d objects, i saved them as iges and imported them into autodesk viz 2007.
The model is fine, but i had some problem with the texture coordinates. Maybe it was too late...
Does moi3d generate mapping coordinates? Is it posibble to check them within moi3d?
Any suggestion is welcome.
regards from basel/switzerland
tosh
161.2 In reply to 161.1
Hi Tosh, I'm glad you like MoI!
> autodesk viz 2007. The model is fine, but i had some problem with the texture
I'm not really familiar with Viz 2007. Somewhere there should be a setting for it to use the UV coordinates of a NURBS surface for texture mapping coordinates - that's probably the setting that you want.
The iges file format does not have anything special in it to represent texture coordinates, but NURBS surfaces have UV coordinates built into them as a part of how the surfaces work, so usually there is a way to use this for texture mapping as well.
For NURBS surfaces (which you get through IGES transfer), the mapping is just built in to the definition of the surface... So in that sense they are generated. When saving to the polygon .obj format, MoI does generate texture mapping UV coordinates for the polygons.
Somewhere there must be an option like "use built-in uv coordinates" or something like that...
Sorry I can't really help you - this is really a question about how things work in Viz, you would probably have better luck asking in a Viz-specific forum...
