How to fix faulty 3dm file?
 1-4  5-24  25-27
1604.25 In reply to 1604.21
> ps I presume I am right in that no adjustment to export settings
> for 3DM can actually be done within MoI?
Yes, that's correct - basically .3dm saves the same kind of data that MoI naturally operates on, so there isn't any kind of conversion options when you save to .3dm from MoI.
1604.26 In reply to 1604.25
Thanks all.
One of my reasons for asking these later questioms is just plain curiosty--the need to learn!
Secondly, there is a lot of good 3dm files stuff about and I have been quite happy in importing a lot of it into Carrara in the past.
Thanks for that Carrara import setting advice
1604.27 In reply to 1604.26
For those with Carrara.
Michaels suggestion to move the angle in the Carrara 3dm dropdown to 3 did increase the number of polys and lessened but did not cure the problem as earlier reported.
OBJ, 3DS and lwo seem to be the better imports into Carrara from MoI---I obviously can confirm!
Brian
EDITED: 31 Dec 2008 by BWTR
Show messages:  1-4  5-24  25-27
