Nurbs Patch Modelling
 1-18  19-38  39-58
1596.19 In reply to 1596.14
Hi Will,
> It's okay Michael, I think we're all just marveling at how
> Jinn was able to model so wonderfully using NURBS.
It's definitely very impressive!
But you have to be careful of a pretty big trap - just seeing someone's impressive result may prove that it is technically possible to achieve something, but it doesn't prove that it is practical to achieve it.
By which I mean if it takes you 3 years of training your skills and then a week of full time work for each model, that is just not going to be very practical for many other people even though it will get great results.
> I don't think we're expecting you to make make MOI into a
> crazy do everything modeler.
:) But that is a pretty natural thing to want. I just have to kind of try and reign in expectations a bit because it's just not practical for that to happen all of a sudden, it will take a fair amount of time to get stuff like new toolsets for different modeling styles implemented.
> I was just voicing that it would be nice for MOI to have
> something that really separates it from Rhino but I guess
> being that you also created Rhino, trying to seperate the two
> may be impossible since they're both your work! :)
Well, not only that but they are both NURBS modelers so certainly that will make for some similarities.
But MoI's interface is different than Rhino's by quite a bit. Things like selection, the display, how you activate tools and set options, all that stuff is different. That's not like a small amount of stuff, those are things that come into play for most every thing that you do...
I guess all that interface stuff seems like a big difference to me.
1596.20 In reply to 1596.19
And what about this t-spline techno ?
http://www.tsplines.com/rhino/video.php
Is it as promising as it looks ? 3*times the price of MoI Oo (+ a rhino licence) ... The obj cage conversion to nurbs looks sweet
to quickly create advanced organic shape ... just wondering how far you can go after that (booleans, fillet, holes, etc ...)
1596.21 In reply to 1596.19
Be sure it is a big difference, I've been using 3d cad for the past 10 years, I've used at least 4 and tried another half a dozen and the learning curve is always where to find the commands and once found what are they capable of.
Finding MoI was god sent. Seriously, the first time I launched MoI it took a matter of minutes to find where everything was and start modeling without looking at a single document and I have never achieved that with any other 3d software.
I watched a tutorial on modeling a car on NPower's 'Power NURBS' and as soon as the dude RMB a menu poppet up that looked like a frigging phonebook listing it scared me :o
It matters to me too, keep going the direction you're going.
Danny
EDITED: 8 May 2008 by DANTAS
1596.22 In reply to 1596.21
Thanks Danny!
1596.23 In reply to 1596.20
Hi PaQ,
It is definitely very promising, it is the kind of SubD/NURBS combination type approach which I think will start to be seen more often in the next 5 years or so.
I don't think that Rhino is really the best environment for creating brand new subd models, it just is not focused on that kind of toolset either. Probably something like Silo or Modo is more likely to be where you would create the models originally.
But Tsplines lets you do some very interesting conversions from SubD to NURBS. Once you have all NURBS surfaces, you can do regular NURBS operations like booleans, fillets, etc... and you could bring those NURBS models into MoI as well.
1596.24 In reply to 1596.23
With all this "options" stuff around!!??
Really, if you do all you can basically in MoI, then take the say .obj file version, to finness, into the, say, Carrara6Pro Vertex Room "Displacement Painting" option----or, maybe even better, doing similarly in the brilliant 3D Coat app---does one really need more?
1596.25 In reply to 1596.19
It is a huge difference to me too. The first time I tried your 'on the fly' construction lines I was hooked ;-)
I've done some interface design in my time and I agree with Danny that this is what makes an application 'work' for the user. Most developers don't understand this and underestimate both the importance of it and the time it needs to design and develop. What I find great is the fact that the first thing you're working on for V2 is a new interaction for scale, rotate, etc. Brilliant!
Please keep up the good work.
I do :-)
But not at version 2. Maybe by version 5 or 10 though. I'm prepared to wait.
Tony
1596.26 In reply to 1596.19
"But MoI's interface is different than Rhino's by quite a bit. Things like selection, the display, how you activate tools and set options, all that stuff is different. That's not like a small amount of stuff, those are things that come into play for most every thing that you do...
I guess all that interface stuff seems like a big difference to me."
Yes, absolutely! Owning Rhino v2 myself, I think I see mostly their similar command sets.
MOI's GUI is so transparent that I guess I sorta take it for granted but yes, the work you've put into the GUI is superb!
Even though I feel it's MOI's exporter that brings the most value for me, I have to say that it is most likely MOI's GUI that has me doing way more that I've ever accomplished in Rhino even though they do have a similar command set!
"> I don't think we're expecting you to make make MOI into a
I do :-)
But not at version 2. Maybe by version 5 or 10 though. I'm prepared to wait"
Actually I do as well! :-) (But I didn't want to tell Michael that just yet! :-P )
-Will
PS - I'd love to see what Jin would have to say about MOI since he's such a great NURBS modeler! Perhaps a CGTalk PM to him with a link here is in order... ;-)
1596.27
Wow !! top mod model export as obj, then convert into t-spline and finally exported in MoI.
Having some trouble with booleans>merge to slice the model ... however it was easy to trim il by hand and doing some cool fillet :)
Incredible modeling perspective for me, but a little bit to much expensive :'(
EDITED: 3 Feb 2010 by PAQ
1596.28
And here's a model coming with modo :)
So cool :)
1596.29
Having a patch modeling toolset is not a "bad" idea. But honestly if you are hoping to make something which handles organic modeling better than subd, i don't think you will achieve it just by using patches. It needs to be something more sophisticated than that if you are to overcome the limitations of working in Nurbs. TSplines is a huge improvement for organic Nurbs, and the poly-Nurbs conversion is awesome. I've used it on a few projects that we are now in process of making the injection moulds. But admittedly there is no modeling toolset (coming in version 2!) which compares to the ease and speed of using subd. However TS for Rhino does have a very nice tool (called tsSkin) that allows the input of a minimal set of curves and can output a smoothed solid model from it. you can define very complex forms with very few Nurbs curves. It's a fresh approach to Nurbs modeling. And i think new concepts like this are needed to make Nurbs a viable organic modeling solution...
jonah
1596.30 In reply to 1596.29
Hi jonah,
Now I'm confused, what method was this Jinwoo dude using, is'nt it Nurbs patches ?
http://forums.cgsociety.org/showthread.php?t=307349
Danny
1596.31 In reply to 1596.28
Hi PaQ,
That one is particularly cool!
You can see that this method has a lot of potential for certain kinds of models where you have some organic / mechanical pieces that need to interact more directly. For example if you needed a face like object that had 100 circular holes drilled in it. Do the face in SubD, bring it over as a NURBS model and drill the holes using NURBS.
However, a lot of times the combination of organic + mechanical is not quite so totally mixed in one single piece like that, like the horse and helmet that you showed earlier seemed like they would work ok with just doing each as separate pieces (organic and mechanical). That seems to be more common.
1596.32
A certain program called 'Animation Master' by Hash Inc., has been doing patch-based modeling from it's inception. A:M uses a patch modeling method that's more akin to Bezier curves than NURBs. Mathematically, they are related since B-Splines are just a generalization of a Bezier curves but the differences presents itself in how we interact with/manipulate them.
The following are links to organic models created with A:M and while they are far from the quality seen in Jinwoo Lee's works, these are done (mostly) by non-professionals and some are actually quite good (note links tagged with a WARNING):
http://www.hash.com/stills/displayimage.php?album=1&pos=197
http://www.hash.com/stills/displayimage.php?album=1&pos=202
http://www.hash.com/stills/displayimage.php?album=1&pos=229 (WARNING)
http://www.hash.com/stills/displayimage.php?album=1&pos=233
http://www.hash.com/stills/displayimage.php?album=1&pos=231
http://www.hash.com/stills/displayimage.php?album=1&pos=232
http://www.hash.com/stills/displayimage.php?album=1&pos=241
http://www.hash.com/stills/displayimage.php?album=1&pos=250
http://www.hash.com/stills/displayimage.php?album=1&pos=251
http://www.hash.com/stills/displayimage.php?album=1&pos=311
http://www.hash.com/stills/displayimage.php?album=1&pos=365
http://www.hash.com/stills/displayimage.php?album=1&pos=369
http://www.hash.com/stills/displayimage.php?album=1&pos=394 (WARNING)
http://www.hash.com/stills/displayimage.php?album=1&pos=422
http://www.hash.com/stills/displayimage.php?album=1&pos=522
http://www.hash.com/stills/displayimage.php?album=1&pos=592 (WARNING)
http://www.hash.com/stills/displayimage.php?album=1&pos=601 (WARNING)
http://www.hash.com/stills/displayimage.php?album=1&pos=649
http://www.hash.com/stills/displayimage.php?album=1&pos=831
http://www.hash.com/stills/displayimage.php?album=1&pos=888
http://www.hash.com/stills/displayimage.php?album=1&pos=931
A modeller named Teyon (Alexander) used to do a lot of organic modeling using Rhino. Nowadays, he prefers to use Silo but samples of his earlier work still exists out on the Web - I suggest using Google to find some of his earlier (NURBS-based) work. At one point, Teyon even discussed his workflow and I remember being shocked at the limited number of commands (from Rhino) that he uses to get the results he was getting.
1596.33 In reply to 1596.30
Hi Danny,
Well, the final output is NURBS patches, but he never goes into very much detail about the specific methods used during modeling.
I had previously assumed that the T-splines plugin for Maya was used for that, but I guess that was not the case. Maya actually natively has some SubD to NURBS conversion capabilities within it as well, for some reason they are not very well known or widely used though.
I think there is a lot of control point manipulation of single patches there, for example in this post:
http://forums.cgsociety.org/showpost.php?p=3192749&postcount=105
> I made type c with just One patch <....>
> <..> Nowadays I mostly use type C because its light and efficient I guess. <...>
So for example that one type of ear is made up of a single surface that probably was deformed by moving its control points around. That's kind of an older style organic modeling workflow that people used before SubD was available when it was difficult to make curved objects out of polygons. NURBS modeling used to be the leading technique for character modeling back then.
So with this kind of thing you're usually looking at the result of a lot of very particular adjustments to control points to sculpt the shape how you want it.
It takes a pretty large amount of time to get enough practice to understand how the resulting surface is going to behave when you move points in a particular way.
SubD tends to be more flexible for this type of thing since it is easier to insert more points into just one spot instead of always having a uniform grid of points like a NURBS surface always has.
Just keep in mind - the main ingredient for producing any of these kinds of really cool detailed organic models is a very high level of skill and fluency on the part of the artist.
It involves the artist spending many many many hours often over the course of many years perfecting their technique so that they gain an intimate understanding of how to adjust points in 3D in subtle ways to get the results they want.
Do not make the mistake of thinking that any of these things are "easy" !
EDITED: 9 May 2008 by MICHAEL GIBSON
1596.35 In reply to 1596.34
I 'C' and ear you :)
I realised this when I surfed around on this subject, plus I think if it was easy you need to have that artistic flair like a sculptor with clay.
We can all get our hands on some clay which will form in any shape you desire but to turn it into art you just have to have that gift.
Thanks for the clarification.
Hi Ambi,
Thanks for the links, and you know that most males still have that 'little boy' tendencies to push the button that says WARNING on them, first ;)
The Manga style is what I'm interested in and I think ? this is achievable in MoI, I've started something along these lines but just need more time and
study as my career involves mainly mechanical parts.
That's part of the reason for the NPR thread. http://moi3d.com/forum/messages.php?webtag=MOI&msg=1553.1
Danny
1596.36
Too bad Tsplines won't see wide adoption as a Subd-NURBS bridge until the patent expires in 17 years. Otherwise, expensive software is the only option...
1596.37 In reply to 1596.30
Hi Danny. What i said was "if you are hoping to make something which handles organic modeling better than subd, i don't think you will achieve it just by using patches". My point isn't that it's not possible, but that there are better and faster ways to get it done. It is impressive that he used Nurbs, but did it result in a "better" model because he spent the extra labor to do it that way? And now with T-Splines it really becomes irrelevant because you can convert the subd model to Nurbs patches... And better solutions will just keep on comng in the future...
jonah
1596.38 In reply to 1596.35
Hi Danny,
Yeah, I think that there is a need for a lot of the same kind of sense of proportion that a good sculptor would have.
But in addition to that, it is kind of its own medium which although similar in some ways is not exactly the same as working in clay. I mean after all you normally work on the computer with a mouse and you don't normally work on clay with a mouse.... :)
So you have to spend a lot of time becoming familiar with the medium itself and learning how it behaves in response to your actions, stuff like that.
On top of that kind of many many hours of experience in the medium, it helps if you study different modeling strategies. There are different ways to manage the organic construction process and since you are dealing with a kind of big sea of points, it becomes pretty important to have a pretty detailed management process that helps keep things organized.
That's a lot of skills that need to be developed that are equally important (well, probably much more important) as the tools.
There is a new type of organic modeling based on brush-stroke type painting which now seems like it may be coming more to the forefront, stuff like ZBrush, Mudbox, and 3D Coat are focused on this different style. It seems like this area has some promise to be an easier to use medium so that it might not require quite as high of a specialized skill training and experience level as subd point manipulation does...
Show messages:  1-18  19-38  39-58
