Wireframe & Quads only request
All  1-2  3-7
1594.3 In reply to 1594.1
Hi Luca, it's not really a full wireframe mode, but on Petr's page here:
http://kyticka.webzdarma.cz/3d/moi/#WireFrameDisplayMode
there is a script that you can set up which will hide all faces leaving only edges being displayed.
It will kind of give you a quick wireframe display but you can't really work on it very easily because things like selection doesn't work very well when no faces are displayed.
I do want to add a proper wireframe mode in the future but it will require quite a few changes to selection, it is not really just a simple change to display only.
One thing for now - make sure you have the options for "Display hidden-line curves" and "Display hidden-line edges" turned on in the Options dialog, under the View section. That gives you a lot of the abilities of wireframe mode even in shaded display because lines that would normally be hidden by the surface shading are visible in the faint dashed line style and can be selected similar to a wireframe display.
re: Quads only option - that is also something that I would like to try adding in the future at some point, but it would involve creating quads that followed trimming boundaries instead of following the natural UV layout of the surface. Unfortunately that's a very difficult thing to set up, it is much more natural from a NURBS processing perspective to quads that are aligned to the UV structure of the surface rather than at any random angle.
1594.4 In reply to 1594.3
Thanks for the "as usual" fast reply.
And yes marcorhino I'm italian.
Ciao
Luca
1594.5 In reply to 1594.4
"All Quads" export is the Holy Grail of 3D modeling, it's also the hardest to achieve!
If Michael was able to pull it off, I believe he'd also be the FIRST to do it!
-Will
1594.6 In reply to 1594.5
NPower has a plugin for Max that does it...
1594.7 In reply to 1594.6
Hi Jonah, I believe that plugin only does it on Polygon objects, not NURBS objects.
I actually have that exact same code available to me over here, it is part of the Solids++ kernel which includes IntegrityWare's polygon mesh library functions as well.
Back a couple of months ago when I saw a bunch of discussions on this, I tried enabling this code and I'm afraid the results were just not very promising - I just did not think that the resulting quality was high enough to really do the job properly. There are some situations where it works ok but it was a very big "hit or miss" type situation.
There were some other issues too - it just wasn't a proper fit for handling curved surfaces instead of planar ones.
Show messages: All  1-2  3-7
