Demo version OBJ export
All  1-2  3-6
1589.3 In reply to 1589.2
i downloaded the moi_v1_trial_setup.exe 9mb version at the dop of the download. When I use save or export with the object selected nothing pops up nor does a file appear where I am saving it to.
It is a demo iges file perhaps it is only lines and no mesh. Do you know where I can get test iges file to test it out?
1589.4 In reply to 1589.3
Hi mnemonicimage, that is the right demo version that does have saving enabled.
But yes - only surface data can be exported to a mesh file format.
If your model consists only of curve objects (like lines for example), then that won't export to a mesh file format.
If you'd like, you can send your model file to me at moi@moi3d.com and I can take a look to see what the problem is.
I don't really know of a good location to download iges files... But to do a basic test you could do something like draw a sphere or box using the "Draw solid" tools in MoI. You should be able to export solids like that to a mesh file.
1589.5 In reply to 1589.4
that was it. I did the sphere and cube in MOI and then it exported fine. Now I have to test it on a larger scale iges model from solidworks. Or do you have a better format for importing solid works files?
1589.6 In reply to 1589.5
> works files?
If you can get it in .3dm format, then that would be better, but IGES is more widely supported.
I think that SolidWorks has a .3dm importer but I think it doesn't have a .3dm exporter, so probably IGES will be the way to go.
Show messages: All  1-2  3-6
