CAM Software
 1  2-21  22-34
Thread Split: Some posts in this thread were moved from here
1586.22
Thanks for the offers guys - but I don't have a model in mind yet. I was just curious if anyone has machined a MoI model, and if so, what software was used.
Here's a possibility:
http://www.deskproto.com/gallery/reference.htm
By the way - my mill has the rotary axis 90 degrees to the spindle, so I can cut around a cylinder.
Machining has its limitations of course. Just because you can draw a model doesn't mean you can machine it. However, for those who make castings, the latest thermal wax printers have incredible accuracy and can pretty much reproduce in 3D anything you can create. I expect MoI to have a market for this type of application. See:
http://www.2objet.com/Misc/Gallery/tabid/70/AlbumID/393-22/Default.aspx
Ed
1586.23 In reply to 1586.22
Hi Ed,
I guess that rules me out for writing any code for you....sorry !!!. I will have a go with Steves model as a
3axis jobby as soon as i get some free time (Trying to learn MoI & Carrara).
All the best,
--Paul
1586.24 In reply to 1586.22
Hi Ed,
I've been using MoI for many of my jewellery designs & output them as STL files for milling.
My mill is a Roland MDX-15 which I've fitted with the rotary unit made by Fourth Axis.
http://www.rolanddg.com/index.html
http://fourth-axis.com/
The CAM software is supplied by Roland as part of their package which uses their own machine code.
There seems to be many 3 axis CAM programs that are fairly cheap, Vectric's Cut3D or Delcam's MillWizard being a couple of them.
http://www.vectric.com/
http://www.millwizard.com/default.asp
But as far as I'm know, once you've moved into 4 axis CAM, there's nothing "cheap".
It seems the starting price for most of them is about $4000 & up!
regards Colin
EDITED: 5 May 2008 by COLIN
1586.25 In reply to 1586.24
Hi Ed / Colin,
Another CAM product that springs to mind on a lesser budget is http://www.onecnc.net/index.htm
Just gives you a few more options to chew over....
Rgds,
--Paul
1586.26 In reply to 1586.25
All right, I was going to stay out of this (so many other resources on the web beside the MoI forum), but....
RhinoCam is a plug-in that runs inside Rhino. So you can ctrl-c in MOI and ctrl-v in Rhino and then toolpath. No importing, saving, or anything else. Basic 2d cam is $1k or less. Continuous 4th axis rotary is an add on to the basic 2d, for another $1k. So, you can have honest to goodness, no BS wrapping, 4th axis rotary toolpath in seconds from MoI.
RhinoCams toolpaths are OK, but not too smart. They STILL dont have a spiral toolpath along the axis, its more like a wrapped XYZ raster. However, this is the cheapest way you can get true 4th axis toolpathing as far as I know.
Mecsoft is supposed to be releasing an improved version in June 2008, but they're ignored critical requests for years, so I'm not going to hold my breath for anything groundbreaking.
I think they have a free demo downloadable on their site, but expect a few calls from Anita the salesperson if you put your real phone # in there. ;-)
EDITED: 5 May 2008 by BODINI
1586.27 In reply to 1586.22
Hi Ed,
You may want to look at Meshcam? http://www.grzsoftware.com/
It does have 4 axis (rotary table) and is only $175
There is a 30 day download (fully functional trial).
It is more of a rapid prototype software, but does have pencil (so concave rads can have finish path). I have downloaded to have a play, but no time until later.
There is also a cutter path verification program there (cutviewer) at extra cost, but both together are only $325, so maybe worth a look?(again you can download a full version trial)
- manz
edit:
Just noticed there is limitation on the 4th axis (rotary) in that :-
1. The 4th axis must be parallel to the X axis.
2. The program zero must be on the left-hand side of the stock and along the center of rotation.
EDITED: 6 May 2008 by MANZ
1586.28 In reply to 1586.27
3. It is indexed only (non-continuous).
1586.29 In reply to 1586.28
Hi Nick,
Yes, it is certainly limited, but I have been looking around for reasonable priced software that may be of interest to Ed.
I have also come across Desk_CNC, http://www.imsrv.com/deskcnc/ again limited on the 4th axis, but does have options for rapping on the 4th axis (to x) which is only indexed machining, but may be of interest.
@$250 with demo available.
@Ed
I am not actually sure at this time as to what the revolve of the 4th axis is, is it the actual table, or is it similar to an indexing/dividing head on x/y? (Z being vertical)
- manz
1586.30 In reply to 1586.29
Hi Steve,
I believe Ed's 4th axis lies along the X axis (ie. 90deg to the Z axis spindle) and therefore rotates along that axis also.
Hope thats make sense ?....Unfortunately I cannot help with code for a 4axis job but I hope to have a go with your model as a 3 axis path as soon as I can.
All the best,
--Paul
1586.31 In reply to 1586.30
Hi Paul,
I did think that, but can also see how the table rotation could be seen as at 90 deg from Z (vertical), so asked for verification.
This thread is certainly making my old brain come up to speed (so I thank all for that) with what is available and (possibly) expected.
- manz
1586.32 In reply to 1586.24
Hi Colin,
Just like you i am designing jewelery so,
I'm just curius about the limitations on the
MDX-15 from Roland
If possible could you show one example of
something of a complex piece you have made
on that machine
1586.33 In reply to 1586.32
Hi Paolo,
Here's a link to a previous post I'd made.
http://moi3d.com/forum/index.php?webtag=MOI&msg=490.1
Here's a link to a Gallery with pieces made by MDX-15 users.
Note that the rotary pieces shown in this gallery have been milled using a totally different rotary system than the Fourth Axis Rotary unit that I'm using.
http://www.3dwaxmill.com/phpBB2/album_cat.php?cat_id=1
regards Colin
1586.34 In reply to 1586.33
Colin thank you for the information
I will overlook it with care next days
Future models will be like this example:
EDITED: 24 Oct 2008 by PAOLOLOBBIA
Show messages:  1  2-21  22-34
