Object size......
All  1-3  4-17
1579.4 In reply to 1579.3
Hi Peter,
> So it would probably be best to deliver the file with a print
> and the sizes marked down with pencil on black and white.....
That's definitely a good idea to do that.
But talk to the people who are receiving your file first, they may have some convention like everything always specified in centimeters, something like that which they may expect for your data to conform to.
1579.5
Thank you very much I will do that.... apart from that I was unlucky to import moi 3d generated
Iges files into Alias studio PLE but was successful to import iges file from Alias studio into Moi 3d but I´m
trying hard to solve that issue.
The guy who makes the other jewels in italy for the jeweler uses Studio..
Peter
1579.6 In reply to 1579.5
Hi Peter, I'm pretty sure that the Alias PLE version is a special stripped down version that has most of the regular file import/export capabilities removed.
So it is difficult to do file imports to that particular version. That version is basically intentionally limited on file handling.
It should work better to import IGES files into the full version of Alias instead of the PLE version.
You might check with the PolyTrans guys (http://okino.com) - I seem to remember that they may have some support for the native Alias ".wire" format, it is possible that they have some kind of converter that could convert from IGES into .wire and that may be possible to read into the Alias PLE version then.
1579.7
Thank you Michael !
I get iges from studio into Moi pretty well !
I will check out Okino !
Peter
1579.8 In reply to 1579.7
Hi Peter, just a note - you'll probably need to e-mail the Okino guys to find out about .wire, I think it may be part of one of their more specialized conversion packs or something.
1579.9
yes I just looked at the standard package and its not in there !
I´ll ask ... thank you very much !
Peter
1579.10 In reply to 1579.9
Hi Rayman,
Take a look at MiniMagics from www.materialise.com
1579.11 In reply to 1579.10
Interesting Paulo
A very poorly designed site to travel around?(Or is that just me today?)'
Seems to be all about Stl files, which I have never seen/used yet (though I gather they are the "newer version off iges?")--but most of my apps can not accept Stl to use anyway
Tis a cruel world!
Brian.
1579.12 In reply to 1579.11
STL files are mostly used by CAM programs.
Oddly enough, I've only ever used STL files because that's what I've needed to mill my designs.
I still haven't done any rendering, so have never needed any of the other formats, only STL.
regards Colin
1579.13
Thank you very much !
I have been investigating this and yes those wax plots use stl files
but most of the service stations that do prototyping also do the conversion
from 3dm to stl for you !They even have programs to look for problem regions in
the files
Peter
1579.14 In reply to 1579.11
Brian,
I friend of my showed me how this program
(magics) worked in combination with rhino40
It came with a Perfactory Envisiontec System
Personally when i browse a site i now already
what i am looking for and won't waist any time
for other things on the site(kind of lazy)
rayman gave me some keywords: jeweler,rings,rapid
prototyping witch made me think of deskproto
and then magics
programs like magics are essential because the STL file
must be absolutely closed
with minimagics(free download) you can analise
if the STL object is valid or not
When you draw complex forms in rhino40 it happens
quiet often (due to experience) that they are still open
So rayman can check his models before he sends them
to his friend
1579.15
Thanks very much just downloaded minimagics !
Looks like its what I was lookink for...
Peter
1579.16
EDITED: 29 Apr 2008 by DANTAS
1579.17 In reply to 1579.16
Peter good luck...
DannyT thank you..
Show messages: All  1-3  4-17
