Villa ~ WIP
 1-2  3-22  23-41
1572.3
Excellent beginning, i am impatient to see the final result (render).
Good continuation.
Best.
1572.4 In reply to 1572.2
>>>Where do you get all the time?
I am semi-retired now, so can find a couple of hours a day to play with modeling.
- Steve
1572.5 In reply to 1572.3
Hi Akram,
I will have to see how I progress. I usually end up getting diverted, but I will try to get this finished fairly quickly.
- Steve
1572.6 In reply to 1572.5
Well, I did divert myself again, but have spent a little time tonight to add some more to this.
EDITED: 3 Aug 2009 by MANZ
1572.7 In reply to 1572.6
Looking very nice Steve, the railings add quite a bit to it.
1572.8 In reply to 1572.7
I did actually enjoy making them, and it has put me in the mood to complete the model.
I also like the fact (after seeing a reply from you on another thread) that I can take high res screen captures directly from MoI (which I did for the above image), certainly saves time having to export/set up and render (certainly for an image to show progress/ non-photo).
- manz
1572.9 In reply to 1572.8
Steve.
How are the file sizes to work with?
Have you been able to satisfacorily separate/group the parts so they can individually be shaded in Carrara?
What file type/settings might you prefer for use in Carrara with this?
(if you have the time to spare!)
Brian
1572.10 In reply to 1572.9
No problem. the complete model (at the moment) is 25mb in 3dm
Yes, I have made various groups, rails / pillars / walls etc (these are in seperate 3dm files, whch I can load into MoI and then export for Carrara). When these groups import, they are still separate, so I can add a variation of texture onto each part in a group, its just a case of better management and each part is a lot easier to find.
I have now gone with 3ds, this does work better when importing the various groups, they import to correct position. Obj format do not load to correct position (I have looked at all the various settings on import in Carrara) Plus, the files size for the model up to now is under 2mb in 3ds.
The output for 3ds is the same as we looked at before~ "Angle at 3", with "avoid smaller than .5". It does look OK on the simple checks. If I do need to change that setting, I will let you know (I wont really know until I start adding textures and rendering).
- manz
1572.11 In reply to 1572.10
Thanks mate.
That all sounds good.
I have heard many reports on "limitations" to 3ds but it looks like the MoI/Carrara compatability is pretty good!(? is there a limit at which the 3ds file size stops working?)
Have you any learning response you can give in relation to
Display settings
Welding vertices along edges
Divide larger than
Aspect ratio limit
Please
Brian
1572.12 In reply to 1572.11
There are limitations, but mainly due to the lack of info within that file type (no UV etc). If I was wanting to export UV co-ordinates / textures etc, then I would use OBJ. But as I will be UV mapping/ texturing within Carrara, then no problems.
There will be a limit due to system memory. If a model is very complex (or with many parts with curved surfaces) then MoI will need a good amount of system memory for the calculations/ storage if you set the angle small, so some caution is needed.
As a little test, I exported the full model (as I am up to) with an Angle of 2 and did not set a "avoid smaller than",.. that produced a polygon count of 3.5 million. MoI during that time used 600mb of memory. Carrara did import the model with no errors.
>>Display settings
In the output of MoI? I usually have that set to shaded+edges, I find it always gives me a better view of the mesh.
I have never found a need to disable that. So I always have weld on.
>>Divide larger than
It is an alternative. As you can leave the main angle high (like 12/15) then just divide the curved surfaces. But, as I have had no problems with the output when rendering, I normally just stay lazy and output as I normally do.
>>Aspect ratio limit
Not really something I have needed to use.
Until I start having problems with my renders, I will just continue to use the output setting I now use. "Angle 3" / "avoid smaller than .5". The weld is enabled by default, so I just leave that.
As they say, "if it ain't broke, why fix it"
- manz
1572.13 In reply to 1572.12
I thought the worst limit for the 3DS format was 65K polygons max?
-Will
1572.14 In reply to 1572.13
Hi Will,
For a single mesh yes. But not for file size. If the mesh size of 65K is reached then the mesh will be split. (the last 3ds file size output I made was 63mb)
- manz
1572.15 In reply to 1572.14
I can't believe Autodesk hasn't done something to fix this. It's laughable at this point... I'm guessing that Max also triangulates your mesh?
jonah
1572.16 In reply to 1572.15
Hi Jonah - well .3ds is a legacy format, it is the format from the old DOS version of 3D Studio. 3D Studio "Max" does not use it as its primary file format.
The .3ds format itself hasn't changed in like 15 years or so.
Really the biggest problem with it is that it does not support vertex normals for shading.
1572.17 In reply to 1572.16
WOW!
Thanks for all that info.
It all clears up that "I wonder if I should" that builds up in the mind.
Brian
1572.18 In reply to 1572.16
Ahhh. I see. So what's the deal with their current primary format? No other software is able to I/O that one?
jonah
1572.19 In reply to 1572.18
Hi Jonah,
They've never documented their primary format.
Basically they set it up as just a container for plug-in data, and plug-ins do all the work reading and writing stuff to the file. So they claim that you can't read the format without the plugins running, that's basically the excuse anyway.
It's a somewhat valid excuse for some things, but also somewhat bogus as well, because there are some common standard plugins that ship with Max which provide basic mesh objects and stuff like that. So it would certainly be possible for them to document at least a core set of information.
But they heavily advise people to write plug-ins to run inside of Max to deal with .max files instead of supporting anyone trying to read or write the format from an external application. So that's what everyone does.
1572.20 In reply to 1572.19
Interesting and surprisingly unsurprising. I see no advantage to this, except to keep people using Max... :\
1572.21 In reply to 1572.6
update:-
1572.22 In reply to 1572.21
Hi Steve, it's looking great - now it's got enough details that it looks very real.
The higher res screenshots are a lot lighter and look nice.
Show messages:  1-2  3-22  23-41
