Filet & Shell
Seems problematic !
And process take some times and gives nothing:) (15 seconds)
(in this example up face has "trimed" edges due the filet ? ) acute angle ?
Does Shell possible after a filet ?
Ps A key "escape process" will be cool :)
EDITED: 9 Oct 2006 by PILOU
157.2 In reply to 157.1
Yeah, this one has a problem surface in it - your fillet was of a greater radius than the bend at one corner of the surface. There is a mechanism built into the filleter that still constructs a surface in these areas, but in this particular case it didn't do a very great job, if you separate this object and turn on control points for that piece, you'll see this:
You can see how dense the control points are in that one region. It probably has very slight wiggles in that area as well. This type of a surface that is very dense with very small wiggles puts a big strain on the surface offsetting, which is the big part of shelling... It's calculating the offset of this one piece that is taking so long.
In general, yes it should be fine with more normal fillets - fillet surfaces that are in normal areas where the fillet radius does not exceed the bend of the surface are a lot cleaner and will work much better.
It does, but that itself isn't really a problem for shelling. There are actually some calculations where trimmed surfaces are better.
I know.... :) It's probably going to come closer towards the end of the beta period after most of the features for V1 are in place.
157.3 In reply to 157.2
Many thx for the explanation!
An alert message when the angle filet radius exceed the bend of the surface will be imaginable?
157.4 In reply to 157.3
I can imagine something for it... Someday... :)
But I need to find a good place in the UI to hold a few lines of text so I can place error and feedback messages there. I can't really imagine popping up message dialogs all the time.
157.5 In reply to 157.4
How about an error message that gently fades away at the top centre of the active viewport? Not conventional, I know. But might be pleasant, and could compliment the current interface.
157.6 In reply to 157.5
Sometimes there might be a few lines of stuff to show though.. It could probably use something where you could scroll back or temporarily expand it to see longer messages.
157.7
PILOU from Zbrush central? Long time no see.
157.8 In reply to 157.7
Yes :)
I had believed to be here incognito :D
Now Zbrush can run without me, I think :)
157.9 In reply to 157.8
Or the Frenchy Pilou from Silo too can be catched here ;-)
157.10 In reply to 157.9
I am afraid that is right also :D
157.11
there is a little smiley icon at Polyloop that goes by the name of Frenchy Pilou as well...
157.12 In reply to 157.11
I must confess that is true too :)
At my known, there is only one rainbow pilou's avatar, it's mine and me :)
If you want see the original size go there (made with Zbrush of course :)
http://www.3dcommune.com/3d/galview.mv?ZBrush+hnisSElqI+1075047342+&v_index=6&nd=1161902302"/img
EDITED: 30 Oct 2006 by PILOU
157.13 In reply to 157.12
He's everywhere! :)
157.14 In reply to 157.13
No, only where that's move & fun :)
