More of Rhino Boat Tute
 1-4  5-24  25-44  45-48
1568.45 In reply to 1568.44
Dirk.
In Carrara, I use the Fresnell plugin shader from here---
http://www.des-web.net/shoestring_graphics.html
Some initial comparrison tests suggest that, as I have normally done, Fresnell needs to be used judicially.
Appreciate comments from others.
EDITED: 15 Nov 2008 by BWTR
1568.46 In reply to 1568.45
yesterday i`ve made some tests again and i couldn`t detect much difference by using fresnel or not.
I am a bit biased by the unbiased renderengines like Maxwell and Fryrender(nice worldplay :-)) and they have turned fresnel all the time on , cause you can`t turn it off. You just change it`s intesity mainly by the ior and by roughness.
I`ve here one tutorial which is about procedural textures in c4d and there the author uses fresnel. Inside the tutorial he has two images, one with fresnel turned on and one without it, so you can compare its effect.
Unfortunenatly the tutorial is in spanish. I can`t speak or read spanish either but the images are named in english so you can easily see of what i spoke here. The link to the english text seems to be broken, so here is the spanish one:
http://www.3dluvr.com/carles/Tut02es.htm
The fresnel effect in a way accents three- dimensionality when there are reflections visible on an object.
Greetings
Dirk
1568.47 In reply to 1568.46
The few quick tests I did shows a softening/degredation of contrasts/shadows on some objects.
That, especially, on objects which should not be reflective.
In Carrara, we have the Reflection channel as basic. The Fresnel plugins being a more "specialised refinement" in that area.
(Carrara is pretty good with it's shading tree variables)
1568.48
Unbiased engines also have blurry reflections/refractions on ALL objects. This is how you find materials in reality. For materials such as glass/chrome, the sampling must be cranked up very high. For biased engines it will make your render time painfully long, but is more accurate...
jonah
Show messages:  1-4  5-24  25-44  45-48
