Surface Blending - Unexpected pinching
All  1-16  17-18
1546.17 In reply to 1546.16
Hi PaQ,
You can construct the blend, it only take a few minutes.
If interested:
I projected line onto center of model, then copy/paste the bottom edges:
I then blend the bottom lines (on each side)
Then blend the top projected lines.
I then made sweep using the 3 blends onto the 2 edges.
The blend was correct.
- Steve
EDITED: 3 Aug 2009 by MANZ
1546.18 In reply to 1546.17
Woooow that's genious !!!
Thank you so much manz explain this trick !
Show messages: All  1-16  17-18
