Modeling a cell phone : Sony Ericsson T650i
 1-19  20-26
1540.20 In reply to 1540.19
Could you please explain that a little bit more? Im still struggling with the array tool.
1540.21 In reply to 1540.18
Hi sayd,
>>>I attached a pic where you can see what i mean.
I had not seen that detail on the pics, so sorry for my confusion.
You will need to create a separate part for that, as you have already boolean out that ear piece.
There are different ways to construct the grid, by either creating a solid shape then boolean out the holes, or by creating the cross sections and boolean them together, or you could even draw the full shape (with holes) and then extrude.
I decided to make the cross sections out of long cubes, I made 2 that crossed each other, then made straight array (which made the needed copies), then boolean together.
EDITED: 3 Aug 2009 by MANZ
1540.22 In reply to 1540.20
The array tool I used for this was the Dir (direction)
I first created 2 long cubes and rotated as needed:
Then selected Array/ Dir
Place the number of copies (top right)
Then select a base point and move the cursor in the direction you want the copies to be made.
1540.23 In reply to 1540.20
The Grid Array is slight different.
First you will have the object to Array:-
Select the Grid Array
Enter the number of copies (how many you want in each direction)
Then enter the spacing:-
OR, use the pointer to set the distance
When done, the Array is made.
Works also with the grid :)
Hum hum ! Boolean union don't works???
(cool for render but in Moi lines don't disapear?
EDITED: 15 Apr 2008 by PILOU
Size: 14.2 KB, Downloaded: 4 times, Dimensions: 414x369px
1540.25 In reply to 1540.24
Thanks guys, i will try this asap!
short update:
EDITED: 15 Apr 2008 by PEBBL
Size: 125 KB, Downloaded: 11 times, Dimensions: 1440x866px
Size: 157.5 KB, Downloaded: 9 times, Dimensions: 1440x866px
1540.26 In reply to 1540.25
Update: Added outer keys
Size: 151.7 KB, Downloaded: 23 times, Dimensions: 1440x866px
Show messages:  1-19  20-26
