My plan, need advice
All  1  2-7
1535.2 In reply to 1535.1
Have you had a good look at the gallery?
Click on the images as working images will then show up as well.
Probably you should be able to do all you need within MoI but MoI exports , for example, ideal .obj files for use in those apps you mentioned.
1535.3 In reply to 1535.2
Yes, I did... great stuff in the gallery.
I have not modeled much. For example, if I wanted to model a wrinkled piece of paper that has been spread flat, would I have an easier time in a box-model polygon program, a freeform sculpt program or in MoI/nurbs or a combination?
1535.4 In reply to 1535.3
http://moi3d.com/forum/index.php?webtag=MOI
Have a look at this thread and how it develops.
Some of other recent threads could be of interest also to you.
1535.5 In reply to 1535.3
Hi shokan,
For that I would just make a deformed plane and add a texture map in an external rendering pgm.
EDITED: 3 Aug 2009 by MANZ
1535.6 In reply to 1535.1
Hi Shokan,
> My question is: will MoI export these roughed out organic
> forms in polygon form that is suitable for detailing/sculpting in
> a program such as Silo or Modo?
For doing detailing using brush stroke type operations, then yes, that method would be fine.
But you generally wouldn't use MoI's output polygons to do further box modeling / 3d point manipulation type detailing where you move individual object points around instead of doing brush-based stuff.
Brush based versus box modeling are pretty separate types of polygon object manipulation methods.
> Would I be better off just doing everything for these objects
> in the other programs?
It's not really possible to give a definitive answer to this without knowing more details about what these objects look like. Just the description "organic forms" is way to vague to really know what you want to do.
For many kinds of details it is a good idea to apply those details just with textures and materials instead of trying to add them as actual model detail at all, Steve shows a good example of this.
> My aim is quick easy "sketching" of the object in 3D in MoI...is
> this something MoI is good for?
Usually yes - in fact this is generally what MoI is all about!
But sketching objects in MoI tends to be driven by drawing and using profile curves that define an object's form.
The more sort of blobby and less distinct an object is, the less easy it becomes to identify profile curves that define it well, and those are the kinds of things that then generally become better to do in box modeling from the beginning.
It is hard to say much specifically without clearer examples of what you want to do though.
1535.7 In reply to 1535.6
That was great advice. Thanks.
Show messages: All  1  2-7
