Headphones
1531.1
Hello everybody,
I juste want to share my first moi model. It's the first time I use nurbs in fact, so I suppose there is some area to improve here and there.
I have the feeling I have lost so many hours using sub-d technique for modeling this kind of objects in the past ^^.
CHeers
EDITED: 3 Feb 2010 by PAQ
1531.2 In reply to 1531.1
Hi PaQ - that is a fantastic result. Great Job!!
I can't believe that's your first MoI model!
It certainly looks like you have settled in to NURBS modeling very well already.
@ PaQ :Pas mal du tout ;)
You must post it in the gallery!
1531.4
Nice job!
See this thread # to make the coiled cable going to the headphone jack:
1519.11
Ed
1531.6
Thanks for the comments.
I didn't had this kind of wire in mind, but it's a good idea.
Just wondering, it seems there is no way to do this helix array around a freeform curve ? Actually it looks like
you can only do it around a circle.
It would be terrific to have a variation of the plugin to do that, but I suppose it's not so easy to do :o) ... something like a Freeform Curve Helix Array.
@Pilou: I will post in the gallery when the model is completely done ;)
1531.7
Got it ... but if someone has a faster way to do it ...
1531.8 In reply to 1531.6
Hi PaQ,
Yeah, I would like to add that capability, but at the moment there isn't enough stuff exposed to scripts to make a plugin for 1.0 to do it.
If you would like to post or send to me your path curve, I should be able to cook up a helix around it pretty quickly for you using some other software.
1531.9
Nice Pair!!!
Marc
1531.10 In reply to 1531.8
Thanks a lot Michael, well I also have some other tool to do it in fact, but I really want to stay in MoI
for this model :)
Little update
1531.11
Your model looks soooo awesome. Wish i could to that. I think i can recognize some elements of the halogen lamp tutorial?^^
How did you apply the "L" on the phones? With text body attachted to the mesh?
1531.12 In reply to 1531.11
Yes, using the text tool (arial font).
Then I have done a fillet at once over the complete letter, a boolean union with the circle.
I had to fight a little bit to filleting the lettre border and the circle ... it was hard to find a 'working' value ...
0.01 ... worked but a little bit to big
0.009 failed
0.002 failed
0.005 failed
0.006 !!! works :)
1531.13
Here's the jack :)
1531.14 In reply to 1531.13
Your so awesome!
looks really nice!!!
If you have tooo much time left. You could make a tutorial! :)
1531.15
Thanks Sayd, well it's probably a little bit early to starting to create tutorial, but why not when I master nurbs a little but more ... (There are so many stuff I don't really understand myself, so I don't want to share bad infos/construction method).
Little update ... still have to fix the wire thickness.
Enough for this night :)
