Files DXF import
All  1-2  3-17
153.3 In reply to 153.2
I use PorgeCAD. E' like AutoCAD approximately. Polytrans converts correctly? Where I find it?
Ste
thanks
153.4 In reply to 153.3
Oops. I have mistaken to write calls ProgeCAD.
153.5 In reply to 153.4
Does ProgeCAD export to any other file formats other than DXF, such as IGES?
I tried the PolyTrans evaluation, and I don't think it will work for you, it is more built to read polygon mesh data out of a DXF file and not to translate curves and lines.
I know that Rhino will work to translate this - you can download a demo version that will save 25 times at http://www.rhino3d.com if you want to try it.
153.6 In reply to 153.5
Unfortunately yes! Does not exist some converter (free) from dxf to igs?
Ste
153.7 In reply to 153.6
< Does not exist some converter (free) from dxf to igs?
Yes :) Amapi 6.1 has these 2 formats Import / export and many other!
Very practical!
Take a look here :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=154.1
Message 153.8 deleted 10 Oct 2006 by MICHAEL GIBSON
153.9 In reply to 153.7
Where is the link for download? But it is a demo version?
Hello
153.10 In reply to 153.9
Excuse me! I have found now I try.
Hello
Ste
153.11 In reply to 153.10
The version that I have found is demo. Where I find the free?
Thank.
Ste
153.12 In reply to 153.11
< Where is the free?
Go there
http://forums.polyloop.net/forumdisplay.php?f=83
It's not a Demo just an "Old Version" but fully powerfull :)
As I said on my post, you mest registere to the forum and write One message "Hello" or any what you want and the "Download" will be autorized!
< This is the Amapi 6.11 for PC. It is the full software, with no limitations. You can save, export, create commercial stuff, with it, etc.
153.13 In reply to 153.12
Thanks!
Ste
153.14
Problem with Amapi! I do not succeed to make to leave the installation! What it can have?
153.15 In reply to 153.14
What is your problem? Have you a Pc Computer?
Have you load the Pc Version against the Mac Version?
Have you copy/past the Serial number from the Readme file?
Have you an xp 64 version?...
< If you have an error with the installer, please, search for this error message in Google.
You will find a fix on Microsoft website, for WinXP. It's not an Amapi installer problem.
I have a normal Xp Version and absolutly no problem for install it!
Maybe disable all Antivirus or firewall before Install ?
The only little prob for me is that you can't close the prog by closing the "WindowsToolbar" so Go Menu File/ Quit :)
EDITED: 11 Oct 2006 by PILOU
153.16 In reply to 153.15
I have a normal Xp Version and i have download the version for pc (Amapi6.1PC_US-FR_polyloop.net.zip) but when i try to install with setup.exe it does not happen null.
153.17 In reply to 153.16
I can't say more than the other guy on Amapi forum :)
Good luck!
Show messages: All  1-2  3-17
