Plaited Rope
All  1-7  8-9
1523.8 In reply to 1523.7
As a once Pro photographer, AND a keelboat owning sailor--and my favourite 14mm lens on the camera, coiled rope right in the very foreground of the shot was --should I say ,"essential"? (And now I struggle and puff to get to answer the front door!---)
I have a plugin shader question, asked of the weave shader maker, on the go.
1523.9 In reply to 1523.4
As Michael said, something like this can (and should) be done as a single tubular surface with displacement/normal mapping. The results are 100% believable and much more easy to deal with for your system. Only a madman would attempt to use thousands of feet of modeled rope in an animation. That being said, carry on with your modeling! :)
jonah
EDIT - Here is a starting point for you to make modeled rope. Select the two clover profiles, then sweep them along the two helices...
EDITED: 8 Apr 2008 by JBSHORTY
Show messages: All  1-7  8-9
