wish: Polygon control
All  1  2-3
1520.2 In reply to 1520.1
Hi Nick, I've added that to the wishlist.
In the meantime, here is a construction technique that you can use to create that kind of polygon right now.
Start with the regular polygon (which makes the "inscribed" inside-the-circle kind) plus its circle like this:
Then run the polygon command again, and drag out some construction lines - put one line at one corner of the polygon and drag it out using tangent straight snap so it is coming off tangent from the circle:
Repeat on the adjacent polygon corner:
Place the center of the new polygon at the same center point, and then use the intersection of these 2 construction lines as its end point, and that will make the outside "circumscribed" style polygon:
Hopefully that will do the job for the moment, but it should not be difficult to add this built in once I am revved up into making new stuff for v2 betas, shouldn't be too much longer before this starts.
1520.3 In reply to 1520.2
Another method - starting with the regular "inscribed" polygon, you can select it and use Transform/Scale to turn it into a "circumscribed" style by doing this.
First point of the scale at the center:
Second point of scale at the midpoint of an edge:
Third point of scale at the endpoint of an edge:
That adjusts the size of the polygon by the exact amount to turn it from an inscribed style to a circumscribed style around the same circle.
Show messages: All  1  2-3
