Tutorial making motor bike gaz-tank
All  1  2-8
1512.2
Thank you for taking the time to make a tutorial. I'm impressed with what this program and it's users can accomplish.
Ed
1512.3 In reply to 1512.1
Cool tut!
Seems all the first part can be made in 2 click !!!
Take a big Sphere : draw the 2 perpendicular curves 'as your models'
"Boolean merge" with one then with the second et voila ;)
Or even just one click with 2 curves and again the "Boolean merge"
EDITED: 31 Mar 2008 by PILOU
1512.4 In reply to 1512.3
Frenchy I didnt quite get it....
when I do what you say I dont get the shape that the
gaz tank should have.
By the way cool tutorial !
Michael it would be cool if we coul add a row of points into this kind of
cage ....
thanks
Peter
1512.5
I think basicaly you could start with every shape
ie this rotated shape to get the starting point.
A sphere has limited amount of points so it can
limit the exact end shape too.
heres what I made from a rotated curve with
more points then a sphere
1512.6 In reply to 1512.3
hi all any easy way to do it is welcom if you can show us picture
i added future to the tank with 2 strip off surfaces 2 click
1512.7
If you look at the bottom of this shape you can see that I started
from a base shape with a sharp corner point.
So this is also a possibility.... it doesnt have to start with a sphere !
You right I don't obtain exactly the same result (see follow):)
Maybe a sweep with 2 rails make the trick ;)
Show messages: All  1  2-8
