Bugs: color values; move tool
151.1
Hello,
New user here!
OMG, what a beautiful, beautiful, beautiful, beautiful concept! It's such a pleasure to work with this proggy! I'm definately going to purchase this when it's available - provided it will be within my budget.
Forgive me if the followings bugs already posted.
Color value entry bug:
1. Bring up a color dialog, such as Options > Background Color
2. In the RGB value fields in the standard color dialog, you can only type in 2 digit values, yet when you pick colors using the mouse, there are clearly 3 digit numbers for RGB.
Move tool bug:
Sorry, I delete this. I was drunk and did something wrong :-)
Requests:
While I'm at it, I'll put in some suggestions/requests/recommendations.
1. Being able to set the color for the interface BG. I refer to the tool bar (light blue) that runs along the bottom and right side.
2. I'm running a 1600x1200 screen and would be nice to be able to drag out the tool panels to arrange them, say, next to each other. I have enough screen realestate to separate, for example, the 'Construct' panel from the 'Transfrom' panel. So I could see the tools in them all at once, as opposed to click 'Construct' once, then click 'Transform' once, etc, etc.
Keep up the GREAT work!
--LES
EDITED: 6 Oct 2006 by PENTOOL
151.2 In reply to 151.1
Hi Les, I'm glad that you like the program!
Thanks for reporting this bug. I have fixed it for the next beta, which should be out in just a couple of days.
I probably won't be able to make a nice interface for changing it soon, but if you want you can edit some of the UI definition files to change it to your liking.
To do this, run notepad.exe, and then open the file moi.css which is located in the MoI program files directory, in a UI subfolder. So the default location for it is: C:\Program Files\MoI beta Sep-26-2006\ui\moi.css .
At the very top of the file you will see this:
.CommandBarBody
margin:0px;
background-color:#D2DFE1;
white-space:nowrap;
.SidePaneBody
Change the background-color entries to a different color. You may want to use this syntax instead: background-color:rgb(<redval>,<greenval>,<blueval>); for instance, background-color:rgb(0,0,0); for black and background-color:rgb(255,255,255) for white. That uses 0-255 rgb values as in the color picker.
After you save the changed moi.css file, you should see the changes the next time you start MoI.
It's going to be quite a bit of work to get a system like that in place. I'm afraid I don't think it will feasible anytime soon. But I am thinking that maybe in V2 I may try to have some smaller amount of drag-customizing probably by letting you drag some of your frequently used tools down to the bottom toolbar in the area between "Object snap" and "Options" that is open. But that is quite a ways away itself.
Please let me know if you find yourself having to very frequently switch between different tabs (and what in particular you're needing to get at). I've tried to cluster related things within a single tab, and my hope is that a lot of the time you will be using some of the same tools that are open for a stretch of time.
