Tutorial
All  1-6  7-13
150.7
Dear All,
So many helpers !!! Wow!
Thanks Pilou ! In four small drawings you have explained EVERYTHING. How can I thank you?
Did you make those sketches especially "pour MoI" ? Excuse the horrid pun - it was intentional.
Now, we have the candlestick sort of figure in the top left corner; how could I pour cement into it (so to speak) and make it a solid?
If I am taking advantage of your favour, then forgive me. We Zoroastrians have a saying," I extended one little finger, and he grabbed my whole arm!".
Thanks George. A sweet, short list that I shall definitely refer to many times. It did help.
Last but hardly the least, Thanks Michael. Yes I know Rhino; I am a sort of paterfamilias and mentor for several jewellery (jewelry to you) schools in Bombay. Strictly honorary jobs and a personal pleasure to do. I had suggested Rhino to several junior colleagues, and together with Ideas it has become almost a standard for us here. I tried it for myself, along with the first several pages of tutorials, but I did not have time to persevere, and so there are specialised teachers in the schools. (Hence the POMPOUS handle Guru etc.).
But, in sheer simplicity, in sheer intuitiveness, in the cleanliness of its interface, its INVITING look, your programme emerges a winner, many lengths ahead. I wish you great luck.
And, when you are ready, perhaps you will allow me to introduce it as distributor to India. My name is Nariman H. Wadia, and I am a consultant to most of the jewellers in my country, mostly as a friend, sometimes as a paid consultant. I make my bread and butter selling complete factories, equipment and supplies. Casting machines, laser welders, laser engravers, small CNCs, usw. I am well known in my field (again the pomposity!) and most designers and manufacturers do know me, as I have been in this line since my early teens, over 50 years. Your price point will sell well here....
Once again How can I thank you, ALL?
Nariman.
150.8 In reply to 150.7
<In four small drawings you have explained EVERYTHING. How can I thank you?
Nothing It's my pleasure :)
< Did you make those sketches especially "pour MoI" ?
Yes just used the key "Print Screen" from my computer of the Moi Canvas and past it in any 2D prog!
5 minutes :)
How could I pour cement into it (so to speak) and make it a solid?
Look the image following : it's an modern candel concept :)
You can apply on some many thing :)
PS < We Zoroastrians have a saying," I extended one little finger, and he grabbed my whole arm!".
It's an universal story it's the same for european people :)
So we are all Zoroastrians :)
EDITED: 7 Oct 2006 by PILOU
Is that normal?
An internal revolve's axe of a close curve don't works?
Maybe a stupid question...but I am perplex :)
150.10 In reply to 150.9
> Is that normal?
Eventually I will automatically trim the profile curve in half at the axis so that this will work.
Without trimming the profile, such a revolve would create a bad surface. I'll try to illustrate why - here is an image of what such a revolve would look like, just revolved by 90 degrees:
You can see that at the top and bottom the surface is compressed to a point in the middle and then flips over itself. This type of a surface is a problem. For things to work well, you should only have surfaces collapsed to a point along an edge (such as with a sphere), not at a point interior to the surface.
You can also see that if you were to continue to revolve another 90 degrees (for 180 total), it would be a closed surface, but it would not close cleanly since the surface's normals would be opposite at the spot where it was touching itself, and it would still have the collapsed point in the middle of it.
Then if you were to try to go by 360 degrees, it would cause it to be doubled over top of itself.
Does that make more sense seeing it in that small increment?
So to make a clean revolve your profile curve should be only to one side of the axis (until I do the automatic trimming). That will create a surface that is collapsed to a point only at its very edge and not right in the middle of the surface.
150.11 In reply to 150.10
< Eventually I will automatically trim the profile curve in half at the axis so that this will work
If it's not a hard work and don't change your pilosophy of the prog that will a cool addition :)
But what append with a curve like that ? That will work too?
150.12 In reply to 150.11
Nope, not too excessively hard. It has actually been on my list for a while. It is not uncommon for people to want to revolve a closed shape through the middle like that.
I'll probably try to cut it with a plane going through the axis line, and then take the larger piece to revolve. So it will work, but you're probably better off making a cleaner profile, you'll just have more control over it.
150.13 In reply to 150.12
< want to revolve a closed shape through the middle like that.
Not only by the middle, by any internal axes !)
< probably better off making a cleaner profile, you'll just have more control over it.
Of course! It' was just for the concept :)
Show messages: All  1-6  7-13
