boolean
All  1-8  9-15
1493.9 In reply to 1493.1
Hi lyes, I have added this to the wishlist.
In the meantime using Copy / Paste like Steve suggested is probably the easiest.
1493.10 In reply to 1493.9
Sorry if I am missing something (not unusual), but if you copy/paste an item, not moving it, and doing the boolean with the copy, would not the original still be in place?
1493.11 In reply to 1493.10
Hi Brian, yes it would be - that is the way to currently achieve that.
What I would actually do would be to first do a copy, then do the boolean, then do the paste after the boolean is all done.
That way you don't have any time where there are 2 copies of an object stacked right directly on top of each other, which can make selection more difficult.
1493.12 In reply to 1493.10
HI Brian you are not missing any thing but you are thausends miles away, hahaha
i added 2 lines to boolean diff script:copy and paste. and is working.
// config: norepeat
#include "GetObjects.js"
function DoDifference()
var objectpicker = moi.ui.createObjectPicker();
objectpicker.allowBReps();
objectpicker.allowCurves();
if ( !GetObjects( objectpicker ) )
return;
var baseobjects = objectpicker.objects;
moi.ui.beginUIUpdate();
moi.ui.hideUI( 'FirstSelectPrompt' );
moi.ui.showUI( 'SecondSelectPrompt' );
moi.ui.endUIUpdate();
return;
moi.geometryDatabase.copyToClipboardCommand( objectpicker.objects );
var subtractobjects = objectpicker.objects;
var factory = moi.command.createFactory( 'booleandifference' );
factory.setInput( 0, baseobjects );
factory.setInput( 1, subtractobjects );
moi.geometryDatabase.pasteFromClipboard();
factory.commit();
DoDifference();
1493.13 In reply to 1493.12
I think I would prefer to keep the simplicity of how it now works.
Especially the idea of withholding the paste until later! I had not given a though to any ability to do that!
And it's everyone usually being 2000miles away from me not the other way around---well I like to think so!
1493.14 In reply to 1493.13
hi Brain sorrey its just a joke i dont know where you are ,
the clever one is michael im just using demo run out in 10 days
1493.15 In reply to 1493.14
Hey! Mine was a joke also!(But you spelt my name correctly!!!!!!!)
With Michael/MoI and Andrew/3D Coat I am living in app heaven!
Show messages: All  1-8  9-15
