Closing a surface
All  1-3  4-9
148.4 In reply to 148.3
So you have not projected to implement Coons Surface or Gordon Curves?
In any case cool trick for the closed object above :)
148.5 In reply to 148.4
I do intend to have these. But even with these, it will still be necessary to create some additional curves to help define the shape of the in-between surface.
148.6 In reply to 148.2
> Question : Only some curves of an object can be "exported" as like an object? (seems not)
I've put this on my list to fix up. Not for the next beta (which I hope to finish soon after I complete the work on quad support), but the one after.
148.7 In reply to 148.6
Your list must be like a Danaide’s barrel :D
148.8
@ Michael :
Thanks ! I will carefully examinate this one and the Crane Hook file you posted some time ago. No doubt that this approach can be useful in a lot of circumstances.
@ Frenchy :
Obviously, Michael understood your question. Not me ! ;-) Can you further explain (maybe with a few french words...)
By the way, do you sometimes sleep ??? ;-)))
Cya
Schbeurd
148.9 In reply to 148.8
@Schbeurd
In french:)
C'est facile : on selectionne quelques courbes d'un objet, et on les "exporte" (menu FIle Export)
Mais ce n'est pas encore possible, dans une ou deux beta peut-�tre :)
PS Of course I am some insomniac :D
Have you seen this video of a crazzy futur game Spore?
Hilarious by Robin WIlliams http://video.google.com/videoplay?docid=1734727723734486891&q=spore
Some more videos exist on the right side about Spore
This prog seems have a tremondous system of 3D creatures creation!
EDITED: 5 Oct 2006 by PILOU
Show messages: All  1-3  4-9
