Surface and PolySurface
1477.1
hi michael i have been modling with moi for weeks and is fantastic specially top down designe aproche
i have tried many mcad software but nothing can match MOI simple flixble powerfull,
there is few things to sort it out hop so:
1- add remove points from surface (isocurve)
2- change surface UV degree with preset like , soft U2 V2 ,normal U3 V3,hard U4 V4 surface .
soft surface is good for sharp edges in single surface
3- change nember off UV and degree on creation off , cylinder ,sphere ,box ,toro
4- color , reflextion ,transparency for surface polysurface
5- groop ungroup objects
6-fix filet and shell
7-stitch surfaces
8- join or heal trimed surface edges
secrets:
offset surface edge will create curve
I added flash video tankyou.
1477.2 In reply to 1477.1
Hi lyes, thanks very much for your feedback!
I should be able to get to at least some of these in v2.
I added all these to the wiki wishlist to keep track of them.
Thanks for the video, that helps clarify things very much!
