Alternate trial version available
All  1-3  4-6
1455.4 In reply to 1455.3
> Do you allow users to do this? I mean I will delete some
> files, change UI, pack all neccessary files into a zip file
> along with moi.ini and send it to a client or colleague?
Hi Petr, it is certainly ok to edit your own local copy, but it is hard for me to generally allow changing and then redistributing the changed software. If I did, then pretty soon someone may try to make changes and incorporate it into one of their own separate products, stuff like that.
However, having said that I certainly don't mind if you send it to just a few clients and make sure they do not post the changed version on a public web site or send it to other people or stuff like that.
If it just stays private between you and a few clients, that's fine.
1455.5 In reply to 1455.4
Sounds like a good opportunity for a "3dm Reader" software (akin to adobe acrobat reader), Michael. :-) Smack some MOI labels and links all over it and distrubite it for free.
1455.6 In reply to 1455.5
Hi Nick, I would like to do that at some point, but there is kind of a fair amount of work to do a nice version of that.
There would be a lot of things I could remove to slim down the viewer quite a lot, and it would probably need some UI design time to retarget it to being a viewer instead of a modeling system like it currently is...
Right now it is a higher priority to spend that time on improvements more directly to MoI first! :)
- michael
Show messages: All  1-3  4-6
