Where can I see the width , length or height or my objects ?
All  1-5  6-9
1452.6
thanks,all of you friends ~
and,the other way,
there is only "Scale" tool,
but I can not just modify object's size with width or width,
I hope v2 can do this also.
ps.I love MoI,and I love this forum too ^^
1452.7 In reply to 1452.6
Hi Jason,
Yup, I'm going to try to make that possible for v2.
1452.8
I use a utility called Screen Calipers with all my graphics programs. It's a caliper than sits on top of your application and allows you to calibrate units and measure distances, even on a angle. I often use it to scale an object in reference to one of a known size.
Ed
1452.9 In reply to 1452.6
Hi Jason,
If you are just trying to change an object width for example, then use the scale 1d. Click on the first corner, then let the cursor snap to the other corner, if you then check the readout at the bottom of the screen it will show you the current size (d) :-
then left click the corner, and move the cursor, you will see the readout change to show the current size.
You can also click in that little window (d) and input a size.
EDITED: 3 Aug 2009 by MANZ
Show messages: All  1-5  6-9
