Open / closed polysurf
 1  2-21  22-27
1447.22 In reply to 1447.20
>>>the "What" command for Rhino v1 did not give size or orientation information on solids.
I know, it would give me the info if the object was closed or not. The script posted to select solids now gives me this info, So not a problem.
>>>If you have Rhino I guess I don't quite understand what the fundamental problem is for you, are you having problems transferring data into Rhino to perform these types of queries?
I personally purchased version1 (on its release) for work, after that, all other versions where purchased by the company, so I do not use them at home.
>>>I can understand that you might have some frustration with this approach if you are more used to the "tons of stuff" kind of approach instead.
It is not a case of "tons of stuff", I was just looking for a simple way to give me ref of an objects position etc. Probably more due to habit rather than a real need.
Steve
1447.23 In reply to 1447.22
Hi Steve,
I see.... unfortunately the 3DM file toolkit only supports reading Rhino v1 files and not writing out to them.
So it only works to copy from Rhino v1 and then paste into MoI, you can't do copy/paste in the other direction like you can with Rhino v2, v3, or v4.
1447.24 In reply to 1447.23
It does not matter, I dont really want to use Rhino at home. I will use MoI. I also have other programs for meshes etc.
Anyway, I have now made purchase of MoI
Steve
1447.25 In reply to 1447.24
Thanks very much for your order Steve!
1447.26 In reply to 1447.25
Just to clarify a thought maybe.
To me, an SR, a point version like 1.1., or a say. 1.1betaA are all the same thing.
Brian
1447.27 In reply to 1447.22
Hi Steve,
But you might use it. Just reread a license conditions.
Petr
Show messages:  1  2-21  22-27
