>>>the "What" command for Rhino v1 did not give size or orientation information on solids.
I know, it would give me the info if the object was closed or not. The script posted to select solids now gives me this info, So not a problem.
>>>If you have Rhino I guess I don't quite understand what the fundamental problem is for you, are you having problems transferring data into Rhino to perform these types of queries?
I personally purchased version1 (on its release) for work, after that, all other versions where purchased by the company, so I do not use them at home.
>>>I can understand that you might have some frustration with this approach if you are more used to the "tons of stuff" kind of approach instead.
It is not a case of "tons of stuff", I was just looking for a simple way to give me ref of an objects position etc. Probably more due to habit rather than a real need.
Steve
