Open / closed polysurf
 1-16  17-27
1447.17 In reply to 1447.12
Hi Steve,
you wrote:
> Sorry, but I am a little confused with your reply on my initial question.
I wrote:
>>There isn't a way to do it right now, but it will be an easy thing to add for V2.
For MoI v1 you need to copy/paste into Rhino for this checking.
>>It is not difficult to add the script interface that will enable this,
I'm not quite sure which part is confusing you? Here I am trying to say that it will be an easy thing to incorporate into the next release, which is currently planned to be the v2 beta release.
But it actually turns out that the script interface is already in place in v1 for identifying closed objects, I was just looking for an "isClosed" method that is not present for surfaces, but there is another way that can be used instead as posted above.
Sorry for getting confused myself on this part!
> (I will say that it is the first 3d application I have used that
> does not give direct feedback of position/ orientation etc of an object.)
But I thought you mentioned previously that you had used Rhino since the first Rhino betas? It's no different over there.
In general CAD programs are not so focused on a kind of generic bounding box / pivot point type approach. Actually usually that type of method is used by applications that are not so focused on precision.
In a CAD program you tend to align an object using some kind of command (like in MoI it would be Rotate) that allows you to snap on to specific individual features of the object and use those to perform the orientation, rather than just some generic spot that is in some arbitrary averaged centroid of the object.
Once you have placed an object in its desired orientation, I guess I don't understand why you want a special readout of it after that, what purpose would that serve for you?
I do expect to add more orientation type functions in v2...
> I would also now need to ask, what do you consider a bug?
> Would this in fact be a need for moi to crash?
It's just the typical definition - something that is malfunctioning.
Missing features that are intended to be added in future versions are not bugs.
1447.18 In reply to 1447.11
> would be a great boon to users if improved in the short
> term rather than waiting for V2.
Don't get me wrong, I certainly agree that it would be useful to users to have new stuff added.
Unfortunately putting out new releases of a finalized version creates a lot of additional work for me, that's what I was trying to explain earlier.
Some logistical things I have to plan around what is efficient and feasible for my own work schedule.
Ultimately being efficient in my work schedule ends up being beneficial in the long run because it means that I can get more new features accomplished overall.
If I had more than 24 hours in a single day, it would be a lot easier for me to do all kinds of extra work all of which would be beneficial to users... But I'm stuck with only 24 hours in a day so there are limits on the amount of work that I am able to produce.
1447.19 In reply to 1447.17
From Rhino release 1. That provided a "what" command, it also had a set of analyze tools, such as length / radius / volume etc, even an option to show broken edges.
So I am not sure as to why you would say "its no different"
I will have a look at the options within the scripts.
Steve
1447.20 In reply to 1447.19
Hi Steve, the "What" command for Rhino v1 did not give size or orientation information on solids.
There was no concept of an orientation attached to an object in Rhino v1.
I do expect to add in a set of Analyze commands to MoI to query things like volume, length, etc... These are not present in version 1.0 though.
If you have Rhino I guess I don't quite understand what the fundamental problem is for you, are you having problems transferring data into Rhino to perform these types of queries?
I can understand that it would be good to have these operations inside of MoI, that's why they are going to be added.
Version 1.0 of MoI is focused mostly on making it quick and easy to draw simple objects, that core mission does not require these types of analysis tools, so that's why they have not been a focus so far.
In general development of MoI is a lot different than development of Rhino. I'm not rushing to throw in every single kind of possible tool I can think of which is what I did with Rhino.
Instead with MoI the approach is a lot more careful and calculated, I'm trying to slowly build things up so that the final result can have a carefully balanced interface.
I can understand that you might have some frustration with this approach if you are more used to the "tons of stuff" kind of approach instead.
Over time I expect for this approach to pay off with plenty of functionality but with with an overall easier and more pleasant to use interface.
This approach may mean that the current version of MoI is not suitable for you and you may have to wait for a while before things kind of bubble up to the level of functionality that you need.
However, having said that there are also a lot of things in MoI currently that you may be interested in as well, so a good approach for you currently might be to use MoI in combination with Rhino instead of expecting to use MoI completely on its own.
1447.21 In reply to 1447.20
Hi Steve, I guess the disconnect is that MoI is not really intended to be like a completely direct replacement for Rhino, it is focused on somewhat different things than Rhino.
There is certainly overlap, and that overlap will grow larger over time, but it just was not a primary goal of MoI to do all the exact same things as Rhino.
I guess that's why it does not seem strange to me to recommend using MoI and Rhino in combination with one another, if Rhino does things that you need that MoI currently does not do.
1447.22 In reply to 1447.20
I know, it would give me the info if the object was closed or not. The script posted to select solids now gives me this info, So not a problem.
I personally purchased version1 (on its release) for work, after that, all other versions where purchased by the company, so I do not use them at home.
It is not a case of "tons of stuff", I was just looking for a simple way to give me ref of an objects position etc. Probably more due to habit rather than a real need.
Steve
1447.23 In reply to 1447.22
Hi Steve,
I see.... unfortunately the 3DM file toolkit only supports reading Rhino v1 files and not writing out to them.
So it only works to copy from Rhino v1 and then paste into MoI, you can't do copy/paste in the other direction like you can with Rhino v2, v3, or v4.
1447.24 In reply to 1447.23
It does not matter, I dont really want to use Rhino at home. I will use MoI. I also have other programs for meshes etc.
Anyway, I have now made purchase of MoI
Steve
1447.25 In reply to 1447.24
Thanks very much for your order Steve!
1447.26 In reply to 1447.25
Just to clarify a thought maybe.
To me, an SR, a point version like 1.1., or a say. 1.1betaA are all the same thing.
Brian
1447.27 In reply to 1447.22
Hi Steve,
But you might use it. Just reread a license conditions.
Petr
Show messages:  1-16  17-27
