Hello
All  1  2-4
1443.2 In reply to 1443.1
Hi Steve, thanks for checking out MoI!
> I have used Rhino since first betas, I did get annoyed that
> I was expected to pay for upgrade to 1.1 just because I
> made purchase of the program early (Mike will remember that)
Pricing for Rhino 1.1 was not my decision...
Normally I would expect that a .1 type version upgrade (like 1.0 to 1.1 or 2.0 to 2.1) will be available for no charge. That's a pretty standard procedure.
But I don't really expect to have a MoI version 1.1, it will probably go from version 1.0 to version 2.0 .
Normally a .1 version would be done if the initial version was sort of a little rough and unrefined and had some things postponed... For MoI 1.0 the beta lasted for quite a long time and the final release is all polished up and already has all the refinement type stuff in it.
I actually kind of prefer to do things in this way - to take some time nailing down the initial release rather than pushing things off to .1 versions or service pack releases. It kind of takes a fair amount of extra time to do this, so that's why it is not quite as common.
> I do not use tablet/pen, so I do find it strange (at first) to find
> my way around the view. But a couple of hours later, strange but OK.
You actually don't have to use any of the stuff that was set up for tablets - mouse navigation stuff like right drag rotate and wheel zooming all works as well.
But yeah the overall UI approach is somewhat different than a standard old-fashioned type application so it can feel a bit strange at first... :)
I'm glad that you like the feel after sticking with it for a bit!
1443.3 In reply to 1443.2
Hi Micheal,
lol, I was not blaming you, just a bit of a rant about Rhino.
I am currently making a model (just a building), if I can complete without MOI crashing or giving me major problems, I will make purchase.
Regards,
edit:
I forgot to ask.
I see moI.exe running, but also see 2 (two) moi_commandprocessor.exe, is that correct?
EDITED: 10 Mar 2008 by MANZ
1443.4 In reply to 1443.3
Hi Steve,
> is that correct?
Yup, that's normal - there may be up to 2 running at any time, each one is used for some slightly different purposes.
Show messages: All  1  2-4
