Few whishes
All  1-3  4-14
1436.4 In reply to 1436.3
I can see it now...
Erwan: "395... 396... 397. There, 397 files imported one by one. Now let's go check the MOI forum."
Michael, your support is beyond belief.
-nick
1436.5 In reply to 1436.4
LOL! But yes, if you have a highly repetitive task please post about it here first so I can see if a script can be cooked up to automate it for you.
1436.6
Oh Michael this is great support and help, many thanks !
About my computer specs, I'm running with 8GB ram but MoI seem to get stuck around 900MB importing the giant .igs
1436.7 In reply to 1436.6
Hi Iwan, I'm glad that multi-import script may be useful! Please let me know if you have any problems with it.
Hmmm, doesn't sound like you are getting stuck with a memory swapping slowdown then...
One thing you might try is turning off the automatic Join that happens on IGES import.
To do that, shut down MoI, then open up the moi.ini file in notepad, moi.ini is located here on XP:
c:\Documents and Settings\ [your login name] \Application Data\moi\moi.ini
Inside of it there should be a section:
[IGES]
JoinOnImport=y
You might try switching that to JoinOnImport=n , and see if that makes the large import come in easier...
1436.8 In reply to 1436.7
hey thanks for the tip, I will try that real soon, I will have to work on another big file from catia :)
Erwan
1436.9
For those interested, it's located here in vista :
C:\Users\[user account name]\AppData\Roaming\Moi
going to test the tip now !
1436.10
ok well, this does work for import speedup but then all patches are exploded into separate pieces and global joining fails.
is this import thing can be multithreaded or something ?
1436.11 In reply to 1436.10
Hi Iwan,
If the model is very complex, you may need to process it more in chunks, like select a batch of surfaces and try to join those, then another batch, etc...
It is hard for me to give more specific advice without being able to work with the model over here, if you want to send it to me at moi@moi3d.com I could try to help out some more.
I guess it is theoretically possible, but it is extremely difficult work to take a large complex piece of code like a file importer and totally change it all to be multi-threaded. That's probably not going to be feasible to attempt anytime soon.
One part that I do want to make multithreaded first will be meshing, which could help this some though too, although really a wireframe display mode would probably be the biggest help for processing large models instead.
1436.12 In reply to 1436.11
OK thank you Michael.
I can't give away the model because, even if I was allowed to, it's 1.5 GB :)
1436.13 In reply to 1436.12
Hi Iwan, is the model just one single huge part?
Or is it an assembly made up of many different parts in it?
If it is made up of many different parts and the parts are organized to belong in different IGES "group" entities, then I think it would be possible for me to improve this by only attempting to join surfaces that belong to the same group. That is a lot more efficient than a total global join attempt.
By the way I just realized that I may have misunderstood your question about multithreading - I do want to make it possible to interrupt a big IGES import, which may involve multithreading for that purpose. The part that will be hard that I was talking about was to try and use multithreaading to improve IGES import performance on multi-core processors, that kind of thing is much more difficult.
1436.14 In reply to 1436.12
Hi lwan,
That is a big file,
I would ask the client for breakdown, or for conversion at source.
Or possibly have at look at http://www2.rhino3d.com/resources/display.asp?language=&listing=414
Show messages: All  1-3  4-14
