Spur Gear Profile
 1-11  12-23
1420.12 In reply to 1420.11
These Gear Fonts can be good fun to use in MoI.
Is there anywhere I could send the zip file for access?
EDITED: 31 Dec 2008 by BWTR
1420.13 In reply to 1420.12
Hi Brian, those look cool - you should be able to post a .zip file as an attachment to a message right here as long as it is not too huge.
1420.14 In reply to 1420.13
OK it did--all have fun.
Brian
1420.15
This is a rewritten version of the original Spur Gear script
EDITED: 7 Mar 2022 by SMIRNOV
1420.16 In reply to 1420.15
This Script has excellent examples of how to code for multiple factories, in htm, if I can understand them.
I see that the function factory(factoryname) is being passed more (parameter) arguments than are declared.
The "argument object "is being used to process the arguments.
http://www.w3schools.com/js/js_function_parameters.asp
The techniques of this script are perfect for a polyskelions script, because I need 2 interpcurve factories.
I've got the two curves coded up already.
The join and circular array will come in handy also. And sliders.
1420.17 In reply to 1420.16
Hi Brian
This factory function trick I found in the old SpurGear script. :)
Unfortunatelly, I can't find the original thread and the author name of this script.
1420.18 In reply to 1420.15
Hi Max,
Could you please explain what the re-written spur gear script does?
1420.19 In reply to 1420.17
See post #3 re Petr ?
I've been looking for a formula for internal spur gears...with ambiguous results so far.
I saw the factory function somewhere else awhile back.
OnClick is used again.
1420.20
Just found this gear generator that might be useful to someone? http://geargenerator.com
BW
Keith
1420.21 In reply to 1420.20
Thanks a lot Keith!
Very useful.
Ciao!
1420.22
Interesting! Thanks! : - )
1420.23 In reply to 1420.15
Hello, I made an update to the gear script.
It adds a checkbox for planetary gears, and creates properly-meshing ring-gear.
Simply Addendum and Dedendum values are switched.
Show messages:  1-11  12-23
