Moi NURBS Lib
142.1
I was trying to get some of my MOI test models via IGES into XSI...just to see what kind of mess XSI NURBS lib is. Well, enough to say...it didnt come in right.
Any chance of you licensing your lib to Softimage? :)
142.2 In reply to 142.1
Actually, yes, they can license most of it from here: http://integrityware.com/ .
Does it have a problem with more complex models, or does it not work even with simple models (like for instance a simple cylinder is a good test because it has some trimmed surfaces in it) ?
It is possible that I could export to IGES with some slightly different settings that might work better, if you have a sample model that doesn't work (preferably one as simple as possible), if you can post the .3dm file here, I can try to export an IGES file with some different settings and send that over to you to see if it works better.
