Lighting again...
All  1-5  6-7
1416.6 In reply to 1416.4
I do want to add different lighting options for v2.
The current one uses a single light but it is a kind of "double-ended" style, like you can see on a sphere that half of the sphere is not dark, there is more of a dark band around the middle which then goes back to light again on the other side.
One benefit of this method is it uses only a single light and is compatible even with very old video cards. I kind of wanted to nail down a basic type of lighting for v1 that would be broadly supported by a lot of even older cards, for v2 I want to mess around with some other lighting options that may require some more modern video cards with shader support.
It is possible in v1 to set up a shortcut key that will flip the light around to a different direction, that can help for now if you want to do some work in an area that is dark, the script for that is here: http://kyticka.webzdarma.cz/3d/moi/#ToggleLightDirection
1416.7 In reply to 1416.6
Ho I didn't know it was a lighting trick for old gfx card.
I'm working on some architecture stuff with a lot of long planar surface, and It's visually tiring ;)
Thanks for the script, I will try it now.
EDITED: 28 May 2008 by PAQ
Show messages: All  1-5  6-7
