Lighting again...
All  1-3  4-7
1416.4
Sorry to up this old post (it's the first one I have found about lighting).
I do agree so much :)
Looks like the fill light is a little bit to low, and looks more like a rim one.
I don't know exactly how it's the lights are setup in the other 3d package.
However here's the modo one:
<atom type="Lights">2</atom>
<atom type="LIntensity1">0.7</atom>
<atom type="LColor1">1 1 1</atom>
<atom type="LAngles1">0.9424778 -0.6283185</atom>
<atom type="LIntensity2">0.3</atom>
<atom type="LColor2">1 1 1</atom>
<atom type="LAngles2">-1.570796 0</atom>
I suspect there is also a ambient value of 5 or 10 % ...
I have attached an image of this default lighting, I have put some specular to have a better view of the lights position.
EDITED: 3 Feb 2010 by PAQ
1416.5 In reply to 1416.2
Certainly would be good for the ability to add / better control of lights, certainly as I am using the high_res screen capture directly from MoI quite a lot.
- manz
1416.6 In reply to 1416.4
I do want to add different lighting options for v2.
The current one uses a single light but it is a kind of "double-ended" style, like you can see on a sphere that half of the sphere is not dark, there is more of a dark band around the middle which then goes back to light again on the other side.
One benefit of this method is it uses only a single light and is compatible even with very old video cards. I kind of wanted to nail down a basic type of lighting for v1 that would be broadly supported by a lot of even older cards, for v2 I want to mess around with some other lighting options that may require some more modern video cards with shader support.
It is possible in v1 to set up a shortcut key that will flip the light around to a different direction, that can help for now if you want to do some work in an area that is dark, the script for that is here: http://kyticka.webzdarma.cz/3d/moi/#ToggleLightDirection
1416.7 In reply to 1416.6
Ho I didn't know it was a lighting trick for old gfx card.
I'm working on some architecture stuff with a lot of long planar surface, and It's visually tiring ;)
Thanks for the script, I will try it now.
EDITED: 28 May 2008 by PAQ
Show messages: All  1-3  4-7
