Filling non planar curves
All  1  2-4
1396.2 In reply to 1396.1
Maybe like this: sorry for the v 1.0 you must trim it ;)
kill the line on the third image before the loft
EDITED: 21 Feb 2008 by PILOU
1396.3 In reply to 1396.1
Hi Brian, normally the best method is instead of using project to make a unfilled curve on your cylinder, use Boolean difference to cut the cylinder with the curve and then you will have all your pieces including your solid filled non-planar piece right from the start.
Here is another discussion thread on this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1359.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=1359.6
In the future I do want to add a command to fill in a non-planar surface, but even when that is in place it will make a far more complex surface than a trimmed extrusion which is what you normally want for such a surface.
If what is shown in the above thread does not work well for you, please post your .3dm model file so I can take a look at your particular situation.
1396.4
Frenchy and Michael, thanks a lot for the prompt response. What a great program. Love it.
Brian
Show messages: All  1  2-4
