Sweep tool problem
All  1-4  5-13
1389.5 In reply to 1389.3
Hi Johny - for the flat option your helix should be oriented along the world Z axis.
So if you go the the right-side view and rotate it 90 degrees, and then repeat it with the flat option it should work how you want.
1389.6 In reply to 1389.5
Thanks Michael, its works well on z axis :)
PS: Wish on v2, its works well on any direction ;)
1389.7 In reply to 1389.6
added to the whish list :)
1389.8 In reply to 1389.7
Thanks PILOU! :)
1389.9
Agreed, having a dependencies on positioning kills a creative session - especially when you don't know (or forget) that a tool has a dependency for this or that...
-Will
1389.10 In reply to 1389.9
Maybe when you choose "flat", I can default to the world z axis direction, but show a button underneath it that says "Set flat dir", and if you push it let you pick 2 points to define the direction.
1389.11 In reply to 1389.10
Why not automatic get helix both end points?
1389.12 In reply to 1389.11
Hi Johny - that would be difficult because the default isn't "flat" mode, it is the freeform twist mode which does not need any direction information.
So that would feel a little odd if I forced you to pick 2 points every time you did sweep, but then did not use that information by default.
1389.13 In reply to 1389.12
Ah, I think you're right Michael ;)
Sorry, I forgot that 3dm file format not save start and end point of created helix information.
And I agree with a button option for select start and end point of direction if we select Flat mode.
Show messages: All  1-4  5-13
