Rendering glitch from 3DM file
All  1-12  13-19
1361.13 In reply to 1361.12
Michael. Thank you for the zip file.
BUT, who, really, would have that "obtuse?" work flow pattern in mind?
Sorry if I am being niggly, just trying to input a thought process that maybe be applicable to us lesser mortals!
1361.14 In reply to 1361.12
> To explain the wierdness maybe?
I think I see - I guess Carrara decided to apply a mirror transform to the object for some reason? I don't know why though.
If you do a mirror in Carrara around the x axis, it looks like it would fix it.
1361.15 In reply to 1361.13
There are a lot of benefits to working in larger sheets like that though, it is a lot easier to adjust the shape and have a smooth flowing result. If you have a ton of little fragments it can be hard to get them to connect up to one another smoothly, it is easy to have creases where they touch each other.
I guess it is just something that gets more natural the longer you do NURBS modeling.
It's kind of a warning sign trying to negotiate around something that seems like a hole instead of trimming it out as a hole.
Also, imagine that you were going to make that hat in real life - would you start with the little pieces you originally had and try to stitch them together, or would you start with a larger piece and then cut it with scissors?
1361.16 In reply to 1361.15
No to worry, but this was my starting point on that hat rim.
Most from there, other than I thought logical, was trying to make good glitches.
Brian
EDITED: 31 Dec 2008 by BWTR
1361.17 In reply to 1361.16
That was a good starting point - actually by using the Planar command you create a large plane that is trimmed by those curves. It is quite similar to the kind of build-large-sheet-then-trim-back method that I showed above.
1361.18
Wasn't there a script posted a while back that enabled you to highlight "open" edges or something like that?
It made a good tool for checking your surfaces to see if they were closed as you expected - actually I think it was perhaps as simple as turning on points? (Or perhaps selecting certain points?) Don't remember now...
-Will
1361.19 In reply to 1361.18
http://kyticka.webzdarma.cz/3d/moi/
there is Select all curve closed here
Show messages: All  1-12  13-19
