Wanted: Explain Curve>Project>Closest pt
All  1-3  4-6
1360.4 In reply to 1360.3
Hi Nick, those are bugs - it isn't very reliable I think with closed curves or when it would have to cross the seam edge of a closed surface.
It's something that I hope to get fixed up in the future when I get some updates to the geometry library that I'm using.
You may try doing something like splitting your closed curve into 2 halves and then try it.
The directional type projection is far more reliable.
1360.5 In reply to 1360.4
Ok... but I wasnt going to use the "B" word on your forum. :-)
I was doing some tests today on the mathmatical accuracy of a projected object... and it was good (arc length, chord length)... and then all of a sudden it wouldnt even project anymore and I thought I was losing my mind!
thanks,
Nick
1360.6 In reply to 1360.5
:) If it is a bug I have no problem calling it like it is!
But some things are not bugs in my own code but rather in the geometry library that I have licensed to use.
Bugs in those areas tend to be more difficult for me to fix, I sort of have to wait to receive an update from them to get them fixed. Some of those may take a while.
Show messages: All  1-3  4-6
