DXF to 3dm
1357.1
I have seen there
OBJ to 3dm(imported as lines)
and 3dm to dxf (to export lines) utlities.
Is there a dxf lines to 3md lines utility somwhere, so we can import CAD lines from programs that don\t support 3dm or IGES?
thanks
1357.2 In reply to 1357.1
Hi Moka, the only DXF to 3DM converter software that I can think of right now is Rhino, it should work for that job.
You might also contact Deelip Menezes at http://sycode.com/ - he has several import/export plug-ins for IntelliCAD, maybe he has something that will work for you using IntelliCAD.
Unfortunately doing an importer is always a lot more difficult than doing an exporter, and DXF is actually a somewhat complex format that can hold a lot of different kinds of things and has several different versions. That means it isn't really as easy for me to quickly make a little utility to help in this case like I did for those other cases.
But I am planning on adding DXF import directly into MoI for v2 though.
One other idea - if your lines are all 2D I think a 2D illustration program like Adobe Illustrator may be able to get them into AI or PDF format. You could also try using one of the PDF printer drivers (like PDFCreator: http://www.pdfforge.org ) and get it out to PDF that way.
1357.3 In reply to 1357.2
thanks for the info Michael,
