Group entity
All  1-11  12-17
1347.12 In reply to 1347.11
Yes, it could affect MOI's selection method on a global scale. Having a specialized "object" mode would allow quicker selections, so you don't have to drill down through the group first. Of course in group mode, selecting non-grouped objects would still act on the individual object. And using the hotkey to flip through them would enable you to quickly select individual objects, press a hotkey to start picking groups, press again to add selection by layer, etc. A good example of this would be modo, where we press the space bar to scroll through sub-object selection modes. The major difference in Moi would be that items don't deselect when switching modes... Take a look at modo for a good example of a smart item managment panel. It can be compressed/expanding simply by dragging it's borders...
jonah
Does a very elaborated system of objects take many place in % of the total prog and can slow down it?
1347.14 In reply to 1347.13
Hi Pilou, part of the planning for that feature will be to make sure that doesn't happen.
1347.15 In reply to 1347.14
Cool :)
1347.16
I think one very important thing when object management is implemented ( layers, groups, whatever they are called in the end) is
to be able to easily import and export while maintaining the oganisation structure,
so that 3dm files are imported according to material or layer assignments,
and obj files are exported with objects group as in MOI
1347.17 In reply to 1347.16
re: file I/O of layers
Hi Moka, that is a really good point.
Some of the organization that I want to allow will not properly fit within the way that OBJ or 3DM files organize their layers.
Probably what will happen is if it is important for you to exactly control the layer / group structure of the output file, then you will need to restrain yourself to only create organizations that fit within that scheme. Like for example only make each object belong to a single tag instead of placing the same object on multiple tags.
I should be able to detect if you have made an organization compatible with the regular layering type system and then utilize it directly in that case, otherwise some portion of your organization will be lost.
Show messages: All  1-11  12-17
