Bend Text
All  1-3  4-8
Another solution for have a concentric projection :)
Ps Better : remplace the circle by a sphere
make the merge (or better Boolean Intersection)
keep the faces intersection, Curves/Project/ mode Closest point!!!
More precise than the Michael hand solution :)
EDITED: 1 Feb 2008 by PILOU
1333.5 In reply to 1333.4
Thanks for the advice. I must be doing something wrong as the projection tool doesn't seem to be working correctly.
If I project with mode = Direction, then the text places curves on front and back sides of the sphere. If I project with mode = closest pt., then no curves are placed on the sphere surface.
Any thoughts?
Regards,
Alan
1333.6 In reply to 1333.5
Without your file seems difficult to answer :)
Upload your 3dm in zip format (button Attachments)
Maybe you deselect something....
1333.7 In reply to 1333.5
Hi Alan - one quick note - the project mode = closest pt is a bit unreliable especially if the curves involved would cross over the "seam" edge of the sphere.
So you may need to rotate your sphere so that the seam edge is not in that area.
Also I don't think that the projection method will work very well with a longer string of text because the projection will tend to kind of collapse down.
You can also try the rotation method that I mentioned before.
1333.8 In reply to 1333.7
<the projection will tend to kind of collapse down
You right ! Letters can't overpass the front diameter, and are deformed on the extremity sides :)
So an another method must be used :)
EDITED: 15 Mar 2010 by PILOU
Show messages: All  1-3  4-8
