sweep
 1-2  3-22  23-26
1328.3 In reply to 1328.2
Ah just read another post and it appears this isn't possible in version 1 which is a shame as it would be a tool i would use often for things like handrails on stairs. I haven't found anything on whether history works with sweep though - im thinking no but i might be doing something wrong. I take it it must be hard to create history for all objects - like extrusion amount and fillet, both of which would be very useful to adjust?
EDIT:sorry you beat me to it Frenchy! yeah the problem is i cant seem to offset the rail correctly.
1328.4 In reply to 1328.3
Lofting chamfers the edges rather than extending them at the corners of the rail. - the profile needs to be scaled at the corners accurately to get the propper corner.
Array file along a curve
Select result : Loft Straigt
1328.6 In reply to 1328.5
Yeah that's the problem - your rail has 4 sides/lines and your resulting shape has 5/6 sides as well as profile distortion around the corners.
1328.7 In reply to 1328.6
You only need two ends and a rail to sweep along I would have thought?
EDITED: 31 Dec 2008 by BWTR
Better : Menu Construct Offset : no problem for found the second curve of the path :)
EDITED: 31 Jan 2008 by MICHAEL GIBSON
1328.9 In reply to 1328.6
this is what happens when the rail is offset. This is just a random shape i know and wouldnt work as a ramp but say i wanted to use the rail as a hand rail and therefore want it offsetting for the other side of the ramp. It seems it's not possible to get a joined up result. A guess a way around this would be to offset it on the ground plane and move each point up vertically.
1328.10
I think I would have done with a sweep of two shapes and arail?
1328.11 In reply to 1328.9
Arrggh this doesn't work either with a 2 rail sweep. See how the junctions don't connect propperly?
1328.12 In reply to 1328.11
Sorry brian perhaps i wasn't clear. Im looking to use sharp corners not smooth curves so the corners mitre. The points will also need to be placed vertically as well - like my first example. The ramp is climbing up if it's not clear from the picture. Thanks though.
1328.13 In reply to 1328.12
Is this more like you were looking for(It was good fun anyway!)
1328.14 In reply to 1328.13
Here is some details of the approach for the corner bits.
EDITED: 27 Sep 2008 by BWTR
1328.15 In reply to 1328.14
hmm i still think its not really the same as what im after. I don't think moi supports it yet. If you look at my last image you will see that using 2 rails the junctions are not clean between sections. your examples appear to be flat or the whole shape angled upwards. I am wanting it to be a continuos ramp upwards with sharp corners.
1328.16 In reply to 1328.15
Kind of done it i think! I just copied and pasted the cross section to all the corners of the rail then using the second rail (that i offset before i elevated the points) as a snap guide i rotated the cross sections individually so the were running from corner to corner of the two rails. I then selected the points on the section and dragged them to snap onto the second rail. Then lofted them all. This has seemed to work and moi's nice snapping and selection and interface made it not too much of a chore!! The next challege comes when doing that with straights and curves - but probably do that in separate objects and join together.
With regard to snapping and construction - is there an option to get more construction lines appearing so a point can be referanced with anothers x and y co-ords more easily?
Thanks for people input to this problem.
1328.17 In reply to 1328.16
Seems at this date you have no need to rotate the sections by hand
just elevate the sections to the curves after the offset + sweep 2 rails from the view top then loft
I believe your function is on the Wish list for the V 2 :)
1328.18 In reply to 1328.17
I don't understand why i don't have to rotate the sections by hand - how do i get them to align corectly at each junction automatically. Using the two rails as a guide is useful to snap everything to. I think perhaps im doing what you are saying i just might not have explained myself very well - i do need to rotate the sections though.
Can't wait for version 2 already!! I take it there is not kind of time frame on the v2 release yet?
1328.19 In reply to 1328.18
< I don't understand why i don't have to rotate the sections by hand
Because the sections have the good orientation on the "flat" plan of the first sweep :)
So you have just to elevate the sections before the straight Loft (or normal if you want a sweet form :)
zip file format 3dm
http://www.divshare.com/download/3659309-13a
EDITED: 31 Jan 2008 by PILOU
1328.20 In reply to 1328.2
Re: History - history will work with Sweep but it is a limitation of history in general that it will only work on commands where there is a single output object generated.
In this case due to the kinks in the rail curve, you're getting multiple separate output objects - that will prevent the history update from working the way it is set up in version 1.0 .
If you do your sweep on a smooth rail curve so it generates one single output object, then history updates will work with it.
I do want to improve history in the future to work in these situations as well, it is just another area like the mitered corners that I wasn't able to get to for version 1.0 .
1328.21 In reply to 1328.18
Hi rhodesy, offset happens relative to a single "up" direction of a plane - it won't be the right thing for a path that is moving around in all sorts of 3D directions.
There is a method you can use to get this type of offset that you want - start with the segmented result of your 1-rail sweep:
Select one common set of outside edges, shown highlighted above. Then hit Ctrl+C to copy those edges, use Undo to remove the sweep, and then hit Ctrl+V to paste in those edges:
Now select just 2 of those edges, and run Edit / Extend. At the Extend prompt it will say "Select boundary objects or push Done for mutual extend" - you want to do the mutual extend operation here, so just push Done or right-click in the viewport. That will extend these 2 pieces so that they touch. Repeat in sets of 2 until everything is touching:
I think that is the kind of offset that you wanted to generate.
However, this will probably not help you for doing the 2-rail sweep workaround, using 2-rail sweep for mitered corners only works well when the rails are on a single plane - when performing it on rails that are moving around in 3D, the sweep happens on each pair of segments separately and there won't be any guarantee that the pieces meet up properly (unless I guess the segments were of equal length).
But you may find that offset method useful for something anyway.
For now to get the kind of mitered corners you want you have to do it manually by creating an extension and trimming the pieces.
When you do the one-rail sweep, turn off end caps so the ends are open. Then you will have this situation:
Select one set of edges along one open end:
Then run Extrude, and set the Cap ends option to off:
Repeat with the other end:
Now select the 2 original pieces:
Then run Edit / Trim, at the "select cutting objects" prompt, press "Done" or right-click to do a mutual trim operation (that is, cutting each object with the other). Switch the trim mode to "Keep", and select the 2 long pieces as the pieces to keep (or alternatively you can keep the trim mode to "Remove" and do a careful window select using a left-to-right window to capture the inside pieces to discard).
Then select the 2 extension pieces:
And run Trim again with the mutual trim method, and this time set trim mode to "Remove" and click on the extra outside pieces.
The result will be this corner:
You can select those pieces and use Edit/Join to glue them together.
I do expect to improve 1-rail sweep to do all this automatically for you in v2.
A variant which you may find interesting is selecting 2 of the open edges at the corner:
And then running Construct / Blend to put in a smooth bit in there:
1328.22 In reply to 1328.18
:) I don't have a time frame planned out for it, but I do hope to get started working on v2 pretty soon, maybe within another month or so.
Once I have some new stuff for v2 I will release beta versions of it which will be available to v1 owners during the beta period.
Show messages:  1-2  3-22  23-26
