Kerkythea
All  1-4  5-12
1309.5 In reply to 1309.4
< Did Frenchy Pilou's tip work for you?
it's works for me and it's the only solution for the path with accent !
(conceptors of Kerkythea are agree with me : it's a bug of English hegemony language ;)
Of course yes you have no problem if you have the luck to have an alphabet without accent :)
EDITED: 27 Jan 2008 by PILOU
1309.6 In reply to 1309.4
Hi Mark / Pilou - one other question - does Kerkythea handle n-gons, or is it better to switch to Output: Quads & Triangles or Triangles only when exporting there?
1309.7 In reply to 1309.6
In all the cases Kerkythea accept all options! Ngones, Quads + triangles, triangles, and transform all in triangles!
I don't know yet for the next release Kerkythea Echo january 30 :)
1309.8 In reply to 1309.6
I generally triangulate using MoI for everything I want to import into Kerkythea. That applied to anything I did from truespace too. If I don't, I can sometimes find additional surfaces in my imported obj. So, when I said K obj import was rock solid, I suppose I should have said it has been rock solid for me providing I triangulate in my modeler first. It could of course be bad modeling on my part. I've attached some example images.
Mark
1309.9 In reply to 1309.8
Hi Mark,
Doesn't look like it to me - it looks like a problem with Kerkythea's triangulation mechanism.
But yes, exporting triangulated from MoI (or probably Quads & Triangles should be fine) should avoid this problem.
It's pretty difficult to make a triangulator that handles all kinds of complex concave n-gons properly, if the algorithm gets confused, it is easy for it to try and connect up a triangle between 2 points where it shouldn't because it will cause a "leak" outside of the boundary.
1309.10 In reply to 1309.9
just a question
when you enable "Weld Vertice along edges" in Moi : there is no parameter for the strength of this process?
because seems export obj to Zbrush : when you subdivise in Zb : objects seems unweld after a first subdivision!
I have retaken the wire model by Shadows44
http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS&msg=103.3
and made some sweep between curves for test :)
EDITED: 31 Jan 2008 by MICHAEL GIBSON
1309.11 In reply to 1309.10
Hi Pilou - I seem to remember that ZBrush does some kind of automatic unwelding when it imports .obj files in some circumstances - I think it is when the welded points have different vertex normals for the 2 faces that share the point.
Since ZBrush is doing this unwelding on import, you'll need to do the weld operation inside of ZBrush to fix it up - I don't know what is called, look for something like "weld", or "merge vertices", or "glue vertices"...
1309.12 In reply to 1309.11
I will examine that :)
Show messages: All  1-4  5-12
