Ideas for MoI 1.0 SR1!
All  1-5  6-10
1289.6
That sounds similar to say FireFox (or even Dreamweaver) extensions - that would be a nice idea for MOI plugins!
It would also be nice to be able to download scripts and >assign on the fly< the key the script will be associated to after its downloaded. I think at this point however we need a key conflict manager so there's no worry of overwriting shortcut key assignments.
Now that I have MOI v1, I have to hunt for all the scripts I had back with the earlier betas (the betas used to keep the scripts setup intact during installation but somewhere along the way, I lost my script configurations and never bothered to set them back up...)
-Will
1289.7 In reply to 1289.6
Hi Will,
Your keyboard shortcuts should have stayed in place (between beta and v1 I mean), since those are stored inside the moi.ini file.
But custom commands that were copied into the \commands subfolder will not be in place for your new V1 installation.
Those ones need to get copied over from the previous beta's \commands subfolder into V1's \commands subfolder.
For v2 I will also try to figure out some centralized place that these files can be stored (similar to moi.ini) so that they can stay installed from one beta to the next.
1289.8 In reply to 1289.7
Hi Michael, no I lost my scripts during one of the beta updates not when going from the beta to the release.
I believe I simply deleted my MOI programs folder at one point and reinstalled MOI fresh - I have some of the scripts I was using saved in a note file so I can get those back when I take the time...
It's just so many script suggestions were flying around here at one point that I sort of fell off on copying them all to that note file I have! :-p
That's why I cosigned on having a scripts/extensions download feature for MOI - to make it easy to see a script you like, specify what shortcut key you'd like to use and then install the extension...
-Will
1289.9 In reply to 1289.8
Hi Will, in the meantime I think Petr has collected up pretty much every one that was mentioned on his MoI page here: http://kyticka.webzdarma.cz/3d/moi/ , you'll probably find your missing ones in there somewhere.
1289.10 In reply to 1289.9
Thanks for the link, Michael!
-Will
Show messages: All  1-5  6-10
