Scale Array Problem
All
1-3
4-6
Brian (BWTR)
19 Jan 2008 (4 of 6)
1285.4
In reply to
1285.3
Quote "make sure to include a single point object"?---all objects + "one arbitary point"?
This "point" I guess is my problem. How do I create it?
(Sorry if the question is a bit dumb--probably kick myself, again, when explained!)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
19 Jan 2008 (5 of 6)
1285.5
In reply to
1285.4
Hi Brian, create the point object by going to Draw curve / More / Point.
The point should be placed at the spot that you want the scaling to happen from, select the point along with your objects when you array them.
See here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109
for the original ScaleArray post that has some more details and an example image.
Let me know if you are still stuck.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Brian (BWTR)
19 Jan 2008 (6 of 6)
1285.6
In reply to
1285.5
Thanks Michael. I was about to post that I had found it.
Thanks to all.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-6
